Question about Plumbing
My sump pump fails to work during big rains. If I
My sump pump fails to work during big rains. If I jiggle the float switch then it pumps. Do I just need to replace the switch on my Zoeller sump pump? I don't know how old the sump pump is. Also, how do I found out what model it is?
Thanks,
Laura
  • 3 Answers
If you dont know how old it is and think it is really old replace floods are never fun
Posted on May 14, 2009
Sumps got a liberty 403 ejector pump hooked to slop sink, vented & drains to water waste line. works well used rarely, recently after 18 snowmelt & rain it stopped going on, leaks from top & smells.?
First check and make sure you have power to the pump. If you do have power, either your float switch is bad, or it is hung up somehow preventing the float switch from rising when the water rises. Remove the lid, and check to see if everything moves freely. After determining that the float is free, grab the float switch, raise it manually, and you should hear the pump turn on. If it doesn't turn on, replace the switch.
Apr 22, 2017 | Plumbing
Miele 1203 washer failed during a cycle and buzzer on no fault lights
check all the wirings connectuions! and maybe you have dirty rottary switch! you can clean the switch!
Oct 01, 2007 | Washing Machines
Sump pump is humming
The float switch may have failed closed so the pump is running continuously. Also, the float switch may be binding on something and not free to switch the pump on and off.
Dec 16, 2012 | Plumbing
My sump pump wont kick off. There is no water in the sump and the float is fine, but the motor won't shut off. I unplugged the pump as to not burn up the motor, and thinking it may reset itself, but when...
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
Jan 09, 2011 | Flotec Automatic Sump Pump Float Switch
I have a flotec model 1m03w fp053200a-o8 1.5 hp sump pump. It run all the time now, the only way it shuts off is if its unplugged. Do I need to replace it, or can it be repaired? Thanks for your time
If you have the pump pictured, there is a float switch in the big round thing that floats. When this float drops, the switch should open and pump should shut off.
Make sure that the pump plug is plugged into the piggyback type float plug.
Jan 03, 2011 | Flotec FP0S3200A-01 1/2 HP 3,200 GPH...
Just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
May 27, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Are the genius switches any better than the float switches?
If you are placing a sump pump in a smaller, more confined area then yes. They both have their downfalls, and either can fail without notice. The ones that slide up and down the rod can get stuck or jammed, sometimes even due to build up on the rod. I tend to favor the genius switches, but either needs to be checked out periodically.
Oct 31, 2009 | Genius Wayne Submersible Sump Pump With ...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
Plumbing Logo
247 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
