Question about AOpen Black 17" CRT Monitor
SOS my screen is pink
I was cleaning my Samsung monitor screen and my screen turned pick.  Can you please tell me how to correct this?
  • Anonymous Apr 08, 2008
    i **** all the tiem
  • 132 Answers
Sounds like your cable got knocked loose a bit off the computer.  Take the cable that leads from the monitor to the computer off completely and then re-apply.  Only tighten it "hand tight", not "super tight".
Posted on Oct 17, 2007
  • 30 Answers
This type of problem are because of the dry joint or the data cable problem. Try to touch the data cable, see the screen is it back to normal or just shoot the monitor see the result. Any more information on repair monitor, please go to . Thanks
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic TH-42PX60U Television
Optiquest monitor screen turned bright pink. How to solve this issue?
First check your cord from the computer to the monitor to make sure the connections are clean and good on the blue vga cord. Plugging it in and out a few times will help clean the pins and holes.
If that is ok: then it may be bulbs.
Pink means that you have bad bulbs inside the screen. sometimes the pink goes away when the bulbs warm up. eventually it won't stay on.
There is a slight chance the power board is also getting weak. You would have to open it up to tell this.
Once partially opened, Disconnect the wide set of wire that goes from the back of the screen to the monitors main video board and then try to turn it on, If it is still bulbs they will really show up with this setup.
If you send me a picture of the power board to, I may be able to tell if the board has issues by looking at the picture of it.
Dec 13, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
My screan has lost white colour and now it displays pink colour.
check your video cable....this is a common problem when a certain pin in the connector is loose
Aug 16, 2009 | Samsung SyncMaster 920NW Monitor
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Screen turn into pink (light rise color)
if you have the skill for take off the cover,take off the metal shield and cables until you reach the CRT board,have a 100watt light on,a solder hot iron in one hand and a few rings of tin in the other, obviously take off the plug and left it over a few meters,and waited a few minutes to give some capacitors discharge time,'s easy !!! resolder the joints that like dark,mainly see the big transistors,(or IC)that have like rings on it's pins, and thats all. I tell you its easy okay then you have to "rebuild" your monitor back.
Jul 09, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
i have a samsung 15inch monitor.which is only 6month blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help mail id is you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Pink horizontal stripes on my monitor
If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
Dec 30, 2006 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
326 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
