LT 157 projector
HI>
Lamp replaced...Still giving error code... error light flashes  amber 10 times then goes steady red.
is it economical to repair.The projector is 5 years old but untill now is exceptional.
Any Ideas.
Regards
Garry.
  • Anonymous Feb 26, 2009
    shutting off, cleaned filters, turns on, get's signal then shuts off after image appears for a few seconds.  not even enough to sift throught the menus.  i believe it has something to do with Eco power management, but unit wont' stay on long enough for me to turn it off.  PLEASE HELP this is for a CHURCH!
  • 2,237 Answers
Reset the lamp timer.
Posted on Dec 22, 2009
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Hi I am having trouble with an LT180 DLP I'm getting a series of error messages culminating in the power light steady orange and the status light flashing a series of 6 flashes red. Inside I found that...
both lights flashing green indicate the projector lost power while it was running (didn't get to go through shutdown procedure). if the status light blinks 6 times, the lamp is failing to strike (one time means the cover is open, 2 times is a temperature issue, and 4 times is the fan). if it comes on and shuts off a short time later (less than 15 seconds), the ballast is going bad and needs replacing. if it didn't come on at all, it'd be either the ballast or the colorwheel. if the lamp light was red, it would be the lamp that needs replacing. nec won't sell parts to anyone who is not an authorized nec service center, so you'd need to contact one to get the part (although they may not sell it to you). but good luck!
Aug 20, 2009 | NEC LT180 DLP Projector
Sanyo XU50 not coming on after lamp replacement
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
May 13, 2008 | Sanyo PLC XU50 Multimedia Projector
TLP-B2 projector lamp problem
my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
Jan 28, 2008 | Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024...
1,034 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
