I have 2 AP 1500 1D amps running 4 XD american bass 12's doesnt sound good when i try to turn it up seems like i cant get the amps to work together how do i need to wire it up
  • blueextc3221
    blueextc3221 May 11, 2010
    and if you need a second opinion on the advice given - post here and i will let you know.
  • blueextc3221
    please describe your setup in detail.
    Start from the radio and work back - including any y cables - line level adapters, crossover, EQs etc.
    The more detail you give the better I can understand your setup... and how to solve your problem.
    I see you have a chat going. And i missed it.
    If your session is not satisfactory - get advice from another expert & Dont rate the session.
kimberleykid
  • 5 Answers
SOURCE: loss of Bass
Hi there, I would think that you have blown your bass drivers in the speakers. Sometime you may have a fuse which is blown in the speaker but this is not usual. Try on another speaker if you can.
Posted on Sep 26, 2007
koolkidkip
  • 3 Answers
SOURCE: Sound quality change
Let me see if I am understanding this.Somehow one chanel of your HK amp was shorted ,But only for an instant.When the wires touched we are hoping that the protection circuitry shut down the HK amplifier . Here are some things you can check:
  1. First and most likely thing: is there any chance that you reversed the speaker leads and now the speaker is playing out of phase from the rest of the system.
  2. You can check and see if it is the speaker or the amp by putting one of the other speakers in the system in that same spot, but make sure that speaker is in phase as well.
  3. Run the channel you think you may have damaged through one of the good speakers that you know is not damaged.
----Phase----
If you set two speakers together, while they are playing they should be beating in and out at the same time. If a speaker is out of phase while one goes in the one that is out of phase will go out and vice versa.
If you still have not narrowed down the problem, there might be a problem with the amplifier itself. For future reference, if I have an amp and speakers that I like, I will put a small fuse right at the point where the wire comes out of the amp: put it on the +(hot) wire. If you have any more questions feel free to ask fixya.com or myself.
If this helps you with your problem, please let us know.
Kool Kid Kip
Pinebeltrecords2@aol.com
Posted on Nov 10, 2007
SOURCE: Legacy LA1020 Low Sound, No Bass
look of rca cable is good
Posted on Aug 01, 2008
  • 149 Answers
SOURCE: Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
Posted on May 30, 2009
loft404
  • 11 Answers
SOURCE: Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Posted on Jun 17, 2009
Set IQ500.4 amp witout tweeq
Car stereo is not easy. It takes a lot of experience and work to get it right. Keep working at it and you will learn what works and what doesn't.
May 03, 2016 | Car Audio & Video
I have a 300 watt alpine 4 channel amp powering 4 x 6.5" kenwood speakers. My speakers can take up to 170 watts each. I have to turn my gain up all the way on my amp in order to get a quality bass...
Your amp is overheating as your speakers all combined are 680 watts, double your max output on your amp. Ideally you need a 1000 watt amp to do the job and for perfect sound as you should never have your amp up to max as it is more likely to blow quicker. The 2000 watt amp your are speaking of will do the job perfect, but you need to keep the gain down around 50% as you could blow your speakers. But yeah all together you are right, the 2000 watt amp will stay cool as doesnt have to work nowhere near as hard as the one you have currently.
Mar 02, 2011 | Alpine Car Audio & Video
May 29, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Playing music for about 2hours and bass amp shuts down
You have maxed out the amp! if your running one 4ga. pwr wire to all your amps, it's choking. Going to Wendy's buying a frosty and sucking it thru a straw!. Your amp is starving for more Voltage and current. That amps peak output is 1200w @ 1ohm, not too shabby! Now onto the next issue: Grounding!, just as important as power! Your amp MUST be grounded properly. Don't ground it to a seatbolt or side wall of the vehicle, go directly to the floor, hopefully less than 2-3ft tops. using the same gauge wire as power. If your power is longer than 12 feet, and in most cars it is, you loose alot of voltage and current flow to the amp the longer the run, the more you loose. That's just how DC power works. What's happening to your amp is it's working itself to death and creating massive amounts of heat. "enough to cook dinner" Run a 2ga or 1ot power wire to a distribution block at the amps. Wire in your other amps, then use the stiffening cap just for the sub amp. Not a cheap answer but it will solve most of your problem. Next, set the gain on the Sub amp NO HIGHER than 1 o'clock. Beyond this, and there's no help for it, there's no more gas pedal to push!. Enjoy your system but don't kill it! Hope this helps
May 23, 2009 | Orion 1200D Car Audio Amplifier
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
HOW TO CONNECT 2 12" KICKER L7 TO A US AMP MD-1D
So you have to run both of the subs to your amp so that its see's 2ohms. The L7's probably have to voice coils to connect both the positive's together and both the negatives together to the positive and negative on your amp
Feb 25, 2009 | Compaq Audio card Sound Card
Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
No bass
There's a small switch on the side labeled LP-AP-HP. Make sure it's in the LP or AP position, not HP. There's a small dial labeled FREQ; if your amp is connected to subwoofers and the switch is in the LP position, adjust the dial until it's set around 80-100.
Jun 14, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
41 people viewed this question
 Grubhead
Grubhead
