Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
I CURRENTLY HAVE 2 X 512 PC2700 DDR MEMORY. COULD 2 X 1 GIG PC3200 DDR MEMORY BE USED ON THIS MOBO ?
    President:
  • 272 Answers
MEMORY PC2700 or PC3200 DDR memory in this mobo ? - ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
Posted on May 14, 2009
  • rjbeg123 May 25, 2009
    The only thanks we get is a rating from you. If my response helped you with your problem please rate me accordingly. If you aren't able to give me a fixya at this time please feel free to ask me more questions until you can. Thanks for using fixya!
  • 6,487 Answers
Yes you can use 2 X 1 GIG stick of RAM for thsi MOBO since the max RAM support is up to 2GIG...
How much ram can I install on my Averatec 2200?
The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Computers & Internet
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
Dec 29, 2010 | Dell Inspiron 1525 Notebook
CAN I INSTALL DDR2 MEMORY OR DO I HAVE TO USE THE DDR TYPE FOR HP PAVILION DV5215US
Your unit uses:
DDR memory with support for DDR PC3200, DDR PC2700 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Each memory slot can hold DDR PC3200, DDR PC2700 with a maximum of 1GB per slot.*
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | HP Pavilion dv5215 Notebook
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Dell Inspiron 2400 Add RAM and Vid card?
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
There u go! and YES, 2GB is tha maximum RAM you can have on that one.
But NO, you can NOT use PC3200 sticks, this is what you can use:
PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
You can read all about in the documentation obove
Good luck
Nic
Apr 09, 2009 | Dell Dimension 2400 PC Desktop
1gb DDR 400 not recognized
That board needs to have minimally memory in pairs .. get another 1Gb stick
Dec 06, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Memory Card for MV42N Motherboard
The Shutle MV42N can take SDRam or DDR
Each memory slot can hold DDR PC2700,DDR PC3200,
up to 2 gig total. the pc 2700 is DDR333 and the PC3200 is DDR400. Why Stop at 256?
Mar 18, 2008 | Shuttle MV42N (SHUTMV42N) Motherboard
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Memory for the D4362
Your system may have 2 slots for SDRAM and 2 slots for DDR Ram, and must not be mixed, either use only DDR DDR2 or SDRAM. The mobo may only take 2 of the same size sticks e.g 2 x 1GB,or 2 x 256MB, so be carefull as you may waste money on a non recognised peice of ram. If you use a pc3200 and a pc2700 stick it will run at the slower speedof pc2700. Some boards will only allow a certain maximum of ram up to pc3200 speed and then adding any more you will have to run at pc2700 speed. The crucial memory site will be best for advice on memory type allowance and speed.
Jan 29, 2007 | E-Machines D4362 (RBD4362) PC Desktop
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
272 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
