Question about Kenmore 63932 Electric Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
I am trying to reinstall a dryer drum belt on my Lg dryer dlg2532W that came off.
  • jsparky Mar 01, 2008
    need to install the belt on to the drum and motor
  • 4,889 Answers
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Posted on Oct 15, 2007
  • eagle338
    eagle338 Oct 15, 2007
    1 New Stainless Steel Flexible Connector -
    Use only if allowed by local codes (Use
    Design A.G.A. Certified Connector)
    2 1/8” N.P.T. Pipe Plug (for checking inlet
    gas pressure)
    3 Equipment Shut-Off Valve-Installed
    within 6’ (1.8 m) of dryer
    4 Black Iron Pipe
    Shorter than 20’ (6.1 m) - Use 3/8” pipe
    Longer than 20’ (6.1 m) - Use 1/2” pipe
    5 3/8” N.P.T. Gas Connection
Tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 | LG DLG5932W Gas Dryer
Dryer drum will not start rotating, until the drum is given a push ... it then turns fine. DLG2532w dryer
The motor is going bad... and will not start on its own...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 12, 2010 | Dryers
DLG2532W dryer not heating up. check filter light is on, but all filters are cleaned.
We have the same dryer and the check filter light always comes on at power up but goes off when starting. Is yours still not heating? as I see you question is a little old now. let us know.
Tim
Jul 05, 2010 | LG DLG2532 Gas Dryer
I HAVE A LG GAS DRYER...MODEL NUMBER DLG2532W...THE PROBLEM, WHEN I WAS ATTEMPTING TO RESET THE THERMOSTAT BUTTOM, I ACCIDENTALLY BROKE A PART THAT HAS A COIL AROUND IT WHICH I THINK GETS HOT AND i THINK...
OK i see the other modle #.
Yes the ignitor can be replaced part# 5318EL3001A
If you have to reset the thermal fuse your vent is clogged so be sure to clean the vent all the way to the outside.
Jan 17, 2010 | LG DLE0332 Gas Dryer
LG DRYER #DLG2532W IS WORKING BUT IS MAKING A LOUD NOISE,WHAT CAN IT BE?
Something was able to get passed the lint filter and into the blower wheel.
Using a flashlight look down and to the left inside in filter housing spin the drum by hand both ways and see if you can see anything.
If you can remove the object.
Some times you can get the object with tape on the end of say a 18" long dowel rod.
If you cant remove the object you will have to call for service.
Jan 14, 2010 | LG Dryers
I need thermostats for LG Gas Dryer DLG2532W in houston TX
Hi, you can order your replacement thermostat parts at the link below.
CLICK HERE
May 21, 2009 | LG Dryers
Kenmore 63932 Electric Dryer Logo
747 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
