Question about Bose Wave Radio
BOSE RADIO WHERE IS THE FUSE ON THE BOSE RADIO AND HOW DO I CHECK IT.
    President:
  • 2,761 Answers
The line fuse for these sets is inside the radio on a printed circuit board. NOTE: for your safety, disconnect the radio from its power source before you open the case and poke around inside. The best way to check the fuse is with an ohm meter, but you can probably check it visually using a strong flashlight. There should be a wire filament running the length of the fuse. If it's intact, so is the fuse. If it's broken or not visible at all, the fuse is "blown" and needs to be replaced. If the fuse checks out ok, the power transformert is likely bad -- a problem that these sets are notorious for. Bose will charge you $100 for the transformer repair (unless the set is still under warranty), and having it done is strictly a matter of personal choice. My choice would be to sell the Bose on eBay as a "tech special" and pick up one of the newer HD radios. They offer much better sound at a much lower price.
Bill B.
Posted on May 19, 2009
Bose radio will not turn on. I have a Bose Wave radio, model AWR1-1W, D.O.M. 980305, that will not turn on. I've verified that there is power to the radio (checked outlet plug of cord). I've looked...
I have the same issue with the same model. I found an open primary winding in the large transformer inside the unit. Now the problem is finding somewhere to buy the transformer...
Sep 19, 2010 | Bose Wave Radio
My bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
May 19, 2010 | Bose Wave Radio
Where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
Aug 07, 2009 | Bose Wave Radio
WHERE IS THE FUSE LOCATED
Bill B.
May 14, 2009 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
120v Bose Wave Radio/CD player plugged into 240V outlet
there is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Jan 13, 2009 | Bose Wave Radio
Bose radio
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 18, 2008 | Bose Wave Radio
BOSE wAVE rADIO mODEL awpc1g
Bill B.
Oct 10, 2008 | Bose Wave Radio
Replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Apr 09, 2008 | Bose Wave Radio
Bose Wave Radio Logo
248 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
