Question about Garden
My boyfriend bought a ford riding mower from his buddy...it was sitting for 2 years...anyway it starts but it is not cutting the grass...why ? The model # is 9809210
  • 3 more comments
  • glo937 May 14, 2009
    the blades are not spinning....
    I think it is a belt drive?
  • glo937 May 15, 2009
    It has a belt drive,the lights do not come on the pto switch..
  • blueextc3221
    blueextc3221 May 11, 2010
    belt drive or Hydraulic?
  • blueextc3221
    are the blades spinning?
  • 61 Answers
Ck blade drive belt.
Posted on Sep 07, 2009
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
The mower just stopped dead.
clean and tighten all connections from the battery to the starter and selenoid connections too
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not start
I have a feeling what happened was you shorted out the ignition switch, somehow. If you can get behind the switch without much trouble, try to jump the wires together 2 at a time just to see if it will jump the , lights, starter, ignition, one of the 3. or get a voltage tester, it will do the same thing. There is a fuse on there in the line, sits next to the battery. check it. Hope this helps,
May 06, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Bolen 17HP riding mower tries to start with key in off position
It sounds like you have an ign. wire grounded or your ign switch has a short in it. Also remove the cover on your starter drive to be sure it has released.
Apr 30, 2010 | Garden
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
