Question about HP DeskJet 5550 InkJet Printer
Orange light is always on
There isnt any paper jammed in the machine, but the orange light remains, the wheels make a banging noiset and try to go round but dont, its the first tiime we have had anyhting wrong with this printer, can you help please?
I have given you my works email address
  • 624 Answers
SOURCE: hp laserjet 6p
The 6p, or at least the ones I?ve seen, have several LEDs so I?m assuming the top one is what is orange. I?ve included the link to the LED codes, however, the three possibilities are top cover open, there is a paper jam or the print cartridge is missing or not installed correctly. LED codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04061&lang=en&cc=us&taskId=120&contentType=SupportFAQ&prodSeriesId=25477&prodTypeId=18972 I would: - try reseating the cartridge - try replacing the cartridge with a new HP one if available. - try blowing out the paper path, could be dust so something small you can?t see. If that fails then its possible you have a failed sensor or electronics board.
Posted on Dec 07, 2006
  • 27 Answers
SOURCE: hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Posted on Mar 09, 2009
  • 52 Answers
SOURCE: cant print, middle orange light always on
replace the cartridge, even a used one will do. If this solve the problem take the chip from the good cartridge and place it on the defective one.
Posted on May 19, 2009
  • 21 Answers
SOURCE: HP F4280 deskjet all in one printer paper feeding problem
See page 94 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
SOURCE: My HP PSC 1402 won't print!
my system ever thing is ok,but once i put paper displaying a out of paper,how 2 resolve this problem
Posted on Aug 16, 2009
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
If the orange light is on and remains on does that mean that the toner is out of ink and needs to be replaced?? When you press print it makes noise but won't print anything and then the orange light is on.
Per Samsungs website:
When the toner cartridge is near the end of its life:
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
Paper jam
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Mar 08, 2010 | Brother Fax-1360 Plain Paper Inkjet Fax
How do I remove a paper jam? The paper is
Feb 04, 2010 | Brother IntelliFAX 4100 Laser Fax
It always says paper jam and it has no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper jammed in the middle and orange light started blinking. How do i make this print again. tried pressing orange and green button to no avail
canon printer. remove all traces of paper in the paper path. remove the power plug and replace after about 30 seconds. restart the machine and clear the orange button.
Oct 17, 2009 | HP LaserJet 1015 Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
3,743 people viewed this question
Seeker5211
Seeker5211
