Vertical line across picture tube on my Symphoic model WF2703.
  • 700 Answers
Is it just folded over with a thin line of light thru the middle of screen. It is a vertical collapse. Vertical Ic is loosing connection with the board or failing Already. resolder first then see if it can actually solve it. If not check capacitor or neighboring components within vertical circuit or replace the vertical IC and check if this solves the problem.
If your not inclened in electronics, have it service by a qualified one.
Posted on May 14, 2009
Sanyo TV Model DS25500. Replaced fuse, but now it has a line across the screen? Does the picture tube need to be replaced?
Your picture tube is fine for now, but it won't be if that line is allowed to burn into the screen. You have lost your vertical deflection. Since a fuse was involved, that indicates that an overcurrent condition existed. You may have a blown vertical deflection IC, or there could be just a shorted diode, which caused the overcurrent, and subsequently burned a resistor in series with the diode, also acting as a fuse. It could be all three.
Apr 05, 2010 | Sanyo Televison & Video
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Line across picture tube
It's a bad solder connection on the vertical IC.It will be mounted on the main board.It is vertical in length and will have thirteen pins..should be marked "LA7838" or similar.
Apr 04, 2009 | Emerson TS2587D 25" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Had the same problem with mine. The vertical hold chip broke loose from the solder,Resoldered it works fine. You will need a magnifying glass to see this on the bottom of the board.
Jan 13, 2009 | Sanyo DS31590 31" TV
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
Horiznal line across screen
The picture tube itself is not longer being manufactured and the replacement might exceed the price of a new TV.
The vertical line you see on the picture tube is not a failure with the picture tube but a different part inside the circuitry.
Dec 07, 2008 | Toshiba CN35F95 35" TV
No picture
Hi
You have defective Vertical output IC. This parts need to replaced to back to normal.
Thanks1
Dec 04, 2008 | Symphonic ST420FF 20" TV
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Televison & Video Logo
355 people viewed this question
Top Televison & Video Experts
Electro Med Services...
