Question about Zanussi ZCM930X Dual Fuel (Electric and Gas) Kitchen Range
Our oven keeps tripping the electricity and we do not know why. it goes up to temperature and then sometime sjust cuts the main straight away or cuts it when the door is being opened or closes. Any thoughts? Mostly goes up to 150 degrees C. Please can someone help?!?!
  • 159 Answers
One of the elements are down to earth or too small breaker
Posted on May 15, 2009
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
Hi can you help me my when i turn it on it reached temperature then triped. Reset the trip switch turned the oven on again and within couple of minuets it happened again. We turned it off and have not used...
Prob your cooling fan...it comes on to keep the appliance at a constant temp and if it doesnt it will trip out. Try turning on ur grill and you should hear the fan come on straight away, if not then you will need to replace it.
Hope that helps.
May 25, 2010 | Baumatic B180 Electric Single Oven
Fan assisted oven
You could try running a hair dryer or even a heater (like an electrical radiator) in the oven.. BUT be careful.. It's possible you might cause overheating of those items Eg melt something or damage an electrical cord etc. You need to drive the moisture away, so the breaker does not trip. But monitor the process closely, as we don't want a fire. Electricians have a special meter called a megger to test the electrical insulation. We are assuming it's just moisture, not an electrical fault causing the breaker to trip. Most problems like this really need a trained tradesperson to faultfind. Take care please, it can be dangerous.
Apr 30, 2008 | Belling XOU592 / XOU593 Electric Double...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Zanussi ZCM930X Dual Fuel (Electric and Gas) Kitchen Range Logo
276 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
