Tried connections a lot still won't work.just tower speakers are working
Make sure you have it in a true Dolby Digital or DTS mode. My guess is that it is switched wrong and not damaged. Please consult your owner's manual. For assistance, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
SOURCE: I have a 5.1 home theater system...HT-813 made by
Refer to the user's manual or press the surround button to set DOLBY PROLOGIC or SURROUND mode.
SOURCE: how can i get the system to work with my tv
if you have it connected with the HDMI cable to your tv, use the ARC on the receiver to hear audio out.
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
