Question about ASUS Computers & Internet
Front panel connectors/jacks is not working
I have a asus p5gc-mx/1333...everything is okay except for the front panel connectors/ jack.....there's 2 usb connector/ports and 1 connector/jack for headphone and 1 for mic on the front panel...only 1 usb connector is working and the rest is not...how can i make all the other connector/jack work especially the headphone and mic...thanks...
  • 6 more comments
  • ejoz May 14, 2009
    no, i'm not the one who built the system.. everything is actually working fine.the speakers are working properly using the back jacks and also the webcam..but when i tried to plug in the webcam on the front panel which have 4 jacks.. 2 usb and a jack for mic and headphone..the audio for the webcam is not working but the one usb is okay...so the webcam is still working but without the sound...i don't know why its not working...i also tried to plug in a headphone on the front panel and same problem...all jacks on the front panel are not working except for the one usb port which i usually use for card reader..thanks i hpoe you can help me..
  • ejoz May 14, 2009
    no i haven't tried to use the front jacks before....except for the one usb port that i usually use for my card reader...i'm actually looking at the manual now....thanks for the help..i appreciate it so much..
  • ejoz May 14, 2009
    can you tell me what to do? so that i won't mess things up...thanks
  • ejoz May 14, 2009
    i opened the case and checked the wires from the front panel onto the motherboard and found out that the front jack ( which is the usb that is working ) is the only one that is hooked up to the motherboard but the rest are not......and i can't find any unplugged wires or something inside...i believe i have to purchase a cable so that i can also connect the other jacks(front) onto the motherboard.....thanks for all the help !
  • ejoz May 14, 2009
    thanks byteguy and ikkenom! you're great!
  • ikkenom May 11, 2010
    Some motherboards have a small jumper that you set to use the "front audio" connectors _instead_ of the "back" audio connectors.
    What specific motherboard do you have?
    If only one of the many USB ports (on the front) are working, then check the wires from the front-panel onto the motherboard.
  • Art Ellison
    Art Ellison May 11, 2010
    Have you tried looking up the manual for that board on the Asus site? They usually have one. It's difficult to help without one, but we can go over it if you want (if you can't find the manual).
    One thing I should ask--have these ports worked in the past? If they have and you haven't messed with the wires, then you have a motherboard problem.
  • Art Ellison
    The front jacks are connected to the motherboard. If you installed this motherboad, they will need to be hooked up according to the manual that came with it.
    Do you have a manual?
    Did you build this system?
    Can you see loose wires coming out of the front panel?
    Did you hook everything up--if so, they might be incorrectly plugged in.
  • 2,229 Answers
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
Posted on May 14, 2009
Where do i hook up the front usb on asus p5gc-mx/1333 motherboard?
Along the edge of the PCB most distant from the CPU,, between the FLOPPY CONNECTOR and the SATA1 jack are two connections.
One is labeled USB56 the other USB78 either one can be used if available.
Aug 31, 2016 | ASUS Computers & Internet
My front audio jacks dont work,please give me a solution
HI
You need to reconnect front audio jack on your motherboard..
thanks for using fixya
regards Sandy Fixya
Sep 18, 2011 | ASUS P5GC-MX/1333 Motherboard
Asus P5GC-MX/1333 system panel connector
is this new if so your book will let you know where it is . if you dont have it you can download at the web site of asus. go to support type in board at the search then download manual from them ok jim.
Jul 17, 2011 | ASUS P5GC-MX/1333 - Motherboard - micro...
Sir i want to connect headphones to my computor but they were not responding so what will i do , i think that there is some problem in sound driver my asus mother board no is p5gc-MX/1333 . PLS REPLY...
Drivers Link for your motherboard.
1. Check where you plug your 3.5mm headphone jack.
2. It should be plugged in the green Line Out connector.
3. Check the Speaker icon on the status bar if muted.
4. Play an audio or video file, wait for a dialog box informing you if sound drivers are not installed.
5. If drivers not installed click the link above, select OS and download.
6. Install the downloaded driver and reboot.
7. Use your headphone in another device for functionality testing. It might be defective.
Hopefully this helps.
Thankyou for posting.
Post your OS for further help.
Jul 14, 2011 | ASUS P5GC-MX/1333 - Motherboard - micro...
What sound driver to download for windows xp? i have a new motherboard P5GC-MX/1333
Go to this link and you might have to install MSUAA before installing the sound driver in order to make the soundcard works
http://support.asus.com/download/download.aspx?
Apr 23, 2010 | ASUS P5GC-MX/1333 Motherboard
Power supply FOR ASUS P5GC-MX/1333
Dear,
Yes you can use that power supply for both one.
Cheers
Jaggu
Oct 18, 2009 | ASUS P5GC-MX/1333 Motherboard
Computers & Internet Logo
1,012 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
