Question about Makita 5/8" 2 Spd Hammer Drill
Damaged chuck I need to replace the chuck on makita hp1620F hammer drill. How do I take the chuck off?
    Problem Solver:
  • 12 Answers
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
Posted on May 14, 2009
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
The keyless chuck on my Makita HP2071F Drill (mains supply) is damaged. How do I replace it?
Open the chuck up fully, and in the bottom there is a reverse threaded lock screw that needs to be removed. (drill it out if you have to, it can be really hard to retrieve). Insert an allen key into the jaws of the chuck and hit the handle with a hammer to turn the hole chuck anti clockwise, firmly and quickly. Replacement is reverse but not so dramatic. Sometimes the chuck is damaged in such a way that it will not grip an (large) allen key sufficiently. You can then peel of all plastic parts of the chuck to expose the core. From here you can weld a metal pice to the chuck in place of an allen key. Take care not to damage the threaded axle from the gear.
good luck
Feb 25, 2011 | Makita & 1/2 Inch Drill
Makita HP 1640 hammer drill chuck loosens grip on drill while drilling
Sounds like the chuck is worn, happens frequently when used often. Here's the link to Makita, their contact info should get you some answers as to what part number is needed as well as the closest location to you for service if required. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=316372
Jan 14, 2011 | Makita HP1640 58Inch Hammer Drill
I want to replace the chuck on my Makita 6280d 14.4v cordless drill. Help please........
The chuck may have a left hand screw insde and at bottom of chuck, some chucks scew on and the screw holds it in place, may have to put an allen wrench in chuck and hit the wrench with hammer one way or the other to losen it.
Dec 29, 2010 | Makita 6280DWPE 14.4V 3/8" Driver - Drill...
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Change the chuck on a makita DA39DA coredlesss right angle drill
look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger.
Aug 20, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Makita 5/8" 2 Spd Hammer Drill Logo
403 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
