Question about Refrigerators
Refrigerator get hot but the freezor is working
Does it of and on. What I be doing I disconnect for awhile and then plug it back. And it will work back.
  • 159 Answers
The freezer is working but the refridgerator is hot the gas in the system are low need to be topped up a bit
Posted on May 15, 2009
Ge profile 2004 open door and temp controls off shut door open they come back on light was staying on sometimes to bottom half of coils in freezor froze freezer working but temp in frig 50s on off fri
It is possible the refrigerator is low on Freon. You will need to remove the back panel inside the rear of freezer to examine the evaporator coils. If only a few rows have frost it will be time to replace the refrigerator. If the control panel in the freezer dispenser are coming on and off there may be a bad connection in the plug under the top left door hinge cover. Check that the plug is tight. Let me know what you see first behind the freezer wall, Thanks Sea Breeze
Dec 12, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Maytag plus i purchased 4 -5 yrs ago went out the freezor over frosted, i defrosted the frige and now the freezor works like a really good refrigerator n the frige side doesnt work.
The thing you need to do determine why it isnt defrosting automatically like its supposed to be sure that you remove the frost from the crossover return hole in the left side wall of refrig compartmentat the bottom by the crisper drawers when its blocked w/frost air doesnt flow correctly into and out of freshfood section.
This is what to check to see why it isnt defrosting by itself;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
oldtech2332_9.jpgoldtech2332_10.jpg-->
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough to yours
Aug 17, 2011 | Maytag MSD2756G Side by Side Refrigerator
Water running from underneath the freezor onto the floor. Water pooling in the bottom of the freezor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing well
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator hot and freezor cold
heatman101
Apr 14, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator not woking
the frezzer is what make the refridge cold it is possable it is going bad also check the plug,breaker,then locate the defrost timer and advance it see if the compresser come on
Apr 12, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Freezor barely freezing, fridge barely cooling
After the electricity came on what setting did you use? I would start out at 4 or 5.When a unit sits too long without running the coolant will settle to the bottom it can be hard on it because it is trying to push it threw the system.After it defrosts all the lines should be clear. From there it could be as simple as the fan in the freezer is slowing down or your compressor is on its way out. Also check the vent from the freezer to the fridge for blockage.
Len
Feb 19, 2009 | Kenmore Refrigerators
Need help on my kenmore refrigerator
hjave you cleaned the coils underneith lately, also when your doing the check toi see if the fan in thje back is working.
Jan 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator
You need a qualified technician for the leak repair and recharging of refrigerant. All of the refrigerant in the system are gone, next time do not use sharp object when cleaning your fridge.
Jan 11, 2008 | Refrigerators
Refrigerator
Sani, see if the evaporator fan is running. That would be the fan in the freezer compartment. It moves the cold air to the bottom. If that is ok, then you may have a defrost problem. Is the freezer panel in back all frosted over? If so, it's probabley a defrost issue. Check these things first and post back...Catriver.
Mar 12, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
