Question about Cooper Lighting Lighted Switch
When a CFL burn it flicker after 2 or 3 sec how to remove it.
    Scholar:
  • 130 Answers
Is the CFL new? If not then it may be lacking sufficient
gas to keep it ignited. Start by replacing bulb.
Posted on Jan 13, 2014
2 Suggested Answers
  • 8404 Answers
SOURCE: compact fluorescent flickers when the switch is off.
You could be getting power from the source in the switch ... does this flickering occur with a non illuminated switch? Have you tried the CFL in other sockets? Have you checked the socket in question for proper polarity? (Hot wire should be broken by the switch and that hot wire should be connected the bottom of the CFL in the socket). Does your switch have a white wire for the neutral connection or are you using the ground wire to illuminate the switch ... or is there a different lind of light in the switch and/or do you know?
Normally ... let me say again ... normally, (in a traditional sense) an illuminated switch should have a neutral connection, a ground lug and the expected 'in' and 'out' for the switch leg. Normally, I would expect the switch leg to use a black from the power source (normally found in the box where the socket is mounted) and a white from the 'off' side of the switch to the socket.
I tried to draw you a diagram ... but it didnt work out and you probably already get the picture.
If everything checks out ... and it still flickers, replace the switch with a non-illuminated switch or use a incadescent light until they are no longer available.
Thanks for your interest in FixYa.com
Posted on Jun 21, 2010
Testimonial: "Common sense most always prevails and your common sense along with your technical knowledge has led me to the conclusion to change back to a regular switch. Sometimes simple IS better."
Replaced cfl bulbs, but the flicker for 15 sec before starting.
Do you have a receiver in the fan or is it direct wired? If it is direct wired and there is no dimmer on the wall it may be a light-limiter issue. Fans roughly 2006 and newer have a limiting device in the light circuit. When they start to fail they are known to flicker or go dead completely. If you find a light limiter most people remove it.
May 03, 2016 | Dryers
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Compaq Presario CQ40 Laptop screen flicker in every 2/3 sec Screen appears like a negative copy. During the fluctuations mouse and keyboard stop working..and zig-zag lines appears at the top of the...
the laptop has some loose connections with display or CFL may gone bad, need replacement.
it is purely technical fault and need an expert to handle, you may contact an expert for assistance..
Nov 08, 2010 | Compaq Presario Notebook
Compact fluorescent flickers when the switch is off.
Jun 21, 2010 | Cooper Lighting Lighted Switch
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Cooper Lighting Lighted Switch Logo
42 people viewed this question
Top Cooper Lighting Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Gene Haynes
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
