Question about Canon MX300 Office All-In-One Printer
Windows doesnt idemtify it
Suddenly windows vista says that the printer is offline though it isnt.ive plugged and unplugged the usb cable a lot of times and have turned off the pc and the printer but its still does the same.what should i do?
  • 114 Answers
Try this.
Go to your control panel and then to Printers
Right click on your printer and select Put Online. See if that works. If not do let me know so that we can research further.
Posted on May 14, 2009
Printer is offline. how do I get it online?
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Feb 28, 2011 | HP Office Equipment & Supplies
It says that my officejet 6210 is offline when i go to print, everything is plugged in though and ive restarted it a couple of times. Was working fine before and now its not.
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
And:
Go to Start-->printers and faxes-->right click on the printer-->properties-->make sure it
Jan 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Windows 7x64, HP8000, Offline
Disconnect the printer.
Click Start
Click Control Panel
Click Printers
How many "copies" of the same printer are installed?
Delete them all
Connect the printer, and let Windows "add printer".
Jul 18, 2010 | HP Office Equipment & Supplies
HP Officejet 5610 All-in-One
this is may be usb cable problem but you follow this steps to get solved Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Dec 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Brother Fax MFC 790CW. Loaded the USB cable from fax machine to my computer and start with it would print from the computer though now it keeps saying offline all the time and even though when I right...
Hi there Jenny, are you using Vista with this printer? If yes, you can to the following:
1. Click the Vista Start button, and go to Control Panel
2. Click Hardware and Sound.
3. Under Printers, c
lick Change default printer.
4. Right click on the printer icon, select Run as administrator, and then click on Properties.
5.
If the User Account Control prompt is displayed, click Continue.
6.
Click on the Ports tab.
7.
Click Configure Port associated to your Brother MFC790c
8. Change the Protocol to Raw.
9. Then click OK.
Restart the printer and try again.
If this does not work, please let me know so that I can suggest other solutions. Goodluck!
Oct 25, 2009 | Brother Office Equipment & Supplies
Its saying printer off line
u get a printer offline when ever the printer cable is unpluged from the system, or drivers not install. what to do if yr sure the drivers r installed unplug the cable to yr system then plug it back. having done so,.....click on start menu, click on printers and faxes, a window will come out right click on the printer icon which u uses u will see an option use printer ofline now left click on it in order to enable the printer.
if this doesnt solve yr problem n u have the software for printer with u. what u do next is uninstall the printer, uninstall the port in which u connect the printer eg(usb,serial,paralel) then retsrt yr system install yr printer back every thing should work well.
thank u
plz come to tell me if done.
May 27, 2008 | HP Office Equipment & Supplies
Problems getting windows vista to see my lexmark x1185 .
  1. Temporarily unplug the power cord from the wall outlet and then plug it back in.
  2. If necessary, turn the printer back on. It should make a resetting sound.
  3. Check that the print cartridge has been snapped into place.
  4. Make sure the printer is directly connected to the USB port on the PC.
  5. If another peripheral device is connected, remove it and connect the printer directly.
Nov 24, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
The printer is offline.
Remove the usb cable from the telephone jack on the back of the printer, and plug it in the usb port.
Apr 16, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MX300 Office All-In-One Printer Logo
154 people viewed this question
old marine
old marine
