Question about LG Studioworks 563N 15" CRT Monitor
Reddishness in the screen
My system developed this problem a month ago. The problem is that color of the monitor is not the normal one. The red color percentage seems to be more. This totally affects the system monitor's look. The screen turns reddish in color. Sometimes this reddishess vanishes when the "Menu" button on the monitor is pressed. Sometimes it remains the same even when the "Menu" button is pressed. What can be done to make this problem set right?
  • 101 Answers
Re: Reddishness in the screen
Have you loaded the drivers which came with the monitor. This will probably allow you to change the settings.
Right click on an area of your desktop and choose properties. Look at the monitor and make sure the resolution is set to the recommended level possibily between 60 or 75 dependant on the model. Also you can get to the display card settings here and change them to suit. Dont get carried away or you can make it so that you cant see whats on the screen at all to be able to change it. Could also be that your monitor is faulty. Check with your manufacturer. It its an old telly type monitor maybe one of the "guns" have gone so you dont get the right colour mix of red green and blue. If this is the case you will need to get a new screen.
Posted on Feb 28, 2008
0 characters
3 Points
How to reset the colours?
the red screen mite mean you lost color control and all your getting is red color nothing else.
Oct 04, 2015 | Computer Monitors
I have a Soyo Monitor MTNIDYLM2286 monitor. It was working fine for 1 year. 4 months ago it lost red and blue color so I replaced the laptop computer connection cord and the color came back. I was away ...
You know if it pops back and forth this could be an indication that the video card on your PC may not be doing well. The way to really make sure is plug your monitor into another working computer and see if you have the same issue if not and the monitor works fine you may want to replace the video card for your computer. Monitors are a dime a dozen these days especially CRTs that would be how I would approach this issue. Do not invest in a repair unless it is a flat screen monitor if you are going to pay for a repair at least do it for a flat monitor I have about 23 of them in my garage giving them away they are around. Thanks for using FixYa! John
Apr 02, 2011 | Computer Monitors
Hello, My name is Diane. I've had my flat screen Acer monitor for 14 months and all of a sudden my monitor has no red, orange or pink color. My screen colors are green, blue and yellow. What is the...
hello Diane, actually yellow is mixed red and green.
I thing you should check your cbf cable first (VGA cable).
Or if you have pattern test, use it to make sure which color has lost.
Change VGA cable may can solve it.
If any problem, please let me know.
Thanks and good luck.
Mar 27, 2011 | Computer Monitors
I purchased my Acer monitor only a few months ago. I opened a very large file (pdf) of artwork for new label hung up my computer due to the large size. However since then my monitor is a...
When you start your computer, if before Windows starts up it's a shade of green, it could be as a result of the screen cable not plugged in properly at some point. If not or if that doesn't work, it could be the software or hardware but I don't know how a pdf can do that??
Feb 04, 2011 | Acer 22" X223w LCD Monitor
My E771 monitor colors suddenly shifted with
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Color and other problems with SyncMaster 910 MP monitor
Go to =>
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung crt 591s blank problem
This eventually happens to all CRT monitors. Either the flyback transformer or some other critical componant has failed, and the screen cannot produce a picture. It might be an easy fix, but it would be better to get a new one.
Sep 09, 2008 | Computer Monitors
LG Studioworks 563N 15" CRT Monitor Logo
99 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
