Question about Nikon Speedlight SB-600 TTL Flash
Quit working My flash quit working just all of a sudden.  I checked the battery and cleaned with an eraser.  No luck.  The flash is almost a year old and was working fine just 2 days ago.  I have a wedding to shoot on Saturday of this week and have GOT to have my flash.  (this is my first wedding!!!!)  HELP!  What am I to do?Thanks, Melanie Deandeanministries@hotmail.com229-891-6923
  • 1 more comment
  • mel4111 Oct 16, 2007
    I took my flash in to a shop yesterday and they told me that sometimes batteries are a little different in length.  Some of the rechargable batteries may push down the little metal pieces that connect and give you juice.  That is what happened to mine.  They went in and lifted the little metal pieces a little and it connected the batteries again.  Such a simple solution to a BIG  problem!!!
  • RicG Nov 07, 2007
    Mel,
    Thank you! I just came back from a shoot where my SB600 dropped out of my pocket when I was climbing a steep ladder to get a rooftop shot. The unit fell about 8 feet to the floor. Totally dead. I don't have time to wait for a repair and was ready to buy a new one from Amazon. I saw your post and, as a last-ditch effort, I went in and tweaked the metal tabs at the base of the battery slots. I thought that there would be tiny chance that the drop may have squished one of the tabs. It worked!!! That's all it was.
    Many, many thanks! Bless you!
    Ric
  • Anonymous Dec 25, 2007
    Changed batteries (re-chargeable) and flash stopped working! I took the batteries back out, simply put them right back in, and it works!
Mel4111,
I dropped my flash just like RicG and found your solution here. I used screw driver to push up the metal tabs until the batter reached high enough to touch the top metal plate again. The metal tabs I lifted up were negative polarity. My flash came back to life. Thanks for your posting. It saved my money.
Posted on Dec 10, 2007
I had this same problem happen two days ago, searched the net vigorously trying to find a solution, finally broke down and called Nikon Support and they are having me ship it in for repair.
Here is a link with the info.
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=336
Tracey
www.dSLRGeeks.com
Posted on Oct 16, 2007
Model JTP15. Why did beeper on timer quit working?
The beeper failed from old age. Sixteen years is a lifetime + in the appliance business.
Mar 02, 2016 | GE Ovens
My remote control quit working. Its less than 1 year Receiver model # VSX-519V
The first thing to try is to clean the battery terminals inside the remote with a qtip and at least 90% isopropyl alcohol, or a pencil eraser. Do the same for the battery terminals, and see if this fixes the problem. If you push the remote buttons while aiming it at a digital camera, you will see a white light, and know that the remote is working. If it's not working, you might be able to find a universal remote to take it's place.
Good luck, hope this helps, and thanks for using FixYa.
Sep 18, 2010 | Audio Players & Recorders
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Scanner quit working on Dell AIO962
Apni ma mt chuudvao mujh se philips walo
Apr 29, 2009 | Dell 924 All-in-One InkJet Printer
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
Seems like batteries don't work, but . . .
I think the problem was either dirty battery contacts or a broken connection somewhere with the battery terminals. I'd cleaned the contacts a number of times with a pencil eraser before, but nothing worked. This time, I just did it again and paid careful attention that both contacts on the battery door were protruding properly--could be that one of the contacts got pushed back such that it wasn't making proper battery contact. All I know is that it's working now, perfectly, after sitting for a couple of years on the shelf. I really like this camera.
Feb 04, 2009 | Sony Cyber-Shot DSC-U30 Digital Camera
No power
Since this generator quit working suddenly it's likley that something is wrong with the field circuit inside. The metal surfaces you cleaned off sound like the slip rings of the rotor, there should have been 2 graphite square rods mounted on the plastic bit you took off that ride on these slip rings, they could be worn down or broken.
You'll need a good DMM to measure the resistance between the 2 slip rings (should be about 15 ohms), also measure each of the stator coils (black and white wires in the molex plug) look for an open.
Because the generator has been sitting for a couple of years it probably also hsa lost its residual magnetism, you'll need to flash the field to get it working again once all the parts are confirmed to be OK.
Oct 07, 2008 | Coleman Powermate Powermate 5000W...
are the contacts corroded or bent?
Oct 01, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
198 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
