Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Is there a program that displays the make of a PC
  • 114 Answers
Go to the Start menu and go to Run.
Type in the Run box, msinfo32.exe
That will show you all the information that you need.
Posted on May 14, 2009
Program too large to fit screen hp mini 110 notebook
Change your screen resolution on the Display in the Control Panel.
Click Start/Control Panel and look for Display or Appearance and Personalization (depending on your operating system). When the Display opens increase the Screen Resolution. The resolution will be under the Settings Tab on the Display. The higher the resolution, the smaller the icons and things will be on the screen, therefore you'll see more.
Apr 19, 2012 | Computers & Internet
I want forms tutorial
Microsoft visual foxpro edition program has an introduction guide on display. Once the program were requested as design would provide tutorial resources. Also, every application that is requested as design should provide resources either as codes, abstruct programs, test algorism. Loading the application shold display the entire resquiured resources usually recognisable in forms, templates.
Feb 22, 2011 | Microsoft Visual FoxPro Professional...
How do you turn the camera on
Find from the list of computer programs windows media 7 player or related. Clicking to display the program should porvide a smaller window area that shows the built in camera in action. Once the program is displayed, the camera is automatically enabled.
Jan 30, 2011 | ASUS Eee 4G Notebook
Computrt turns on no picture? HP Pavillion a 262
The computer displays logos from the manufacturer during, before programs are loaded onto the screen. Once a program has been selected with movie functionalities, several sequencies of pictures make up movies. A no picture display is indication of malfunction of the computer default causing the user programs tobe displayed.
contact a technical expert
Dec 21, 2010 | HP Computers & Internet
We just got a new computer with Windows 7. We
You could try installing the version 5 on your pc. There could be a compatability issue so follow the information below if it will not install.
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Apr 01, 2010 | The Learning Company The Print Shop...
My Sony NS series notebook displays message that
probably some of your softwares need to have a start up program in order to work properly.
Check your computer if it has a program that needs to have a startup program.
Aug 13, 2009 | Computers & Internet
I deleted programs and i think I deleted a driver becuz when I restarted computer I got blank screen that read "cannot display this video mode". How can I fix it?
Hi there
bring your pc up in safe mode by pressing f8 untill you get the start up menu then select safe mode once the pc is up rght click on a blank area of the desktop .select properties ,settings, then advanced change the refresh rate down to 60hz then restart as normal your pc should now display
Regards Al "alstech"
May 26, 2009 | E-Machines eMachines Desktop PC
Te-2200 does'nt work
Hi.
You may have lost all of the programming.
I need to see the MAC code.
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down.
Turn power on at wall.
When you see 'FFFFFFFFFF' on display, let go of RECEIPT FEED.
Press SUBTOTAL
Now look at the print out and tell me what the big number is right at the bottom.
Mark
Nov 27, 2008 | Casio Parts Cash Register PC Desktop
Monitor not working
try going to safe mode,restart pc then press f8 for advance boot menu,go to safe mode,choose administrator,reenable display adapter again..eiether thru device manager or display properties
Jun 25, 2008 | Acer Aspire 3680 Laptop
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
20 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
