Question about Maytag Neptune MDG6700A Gas Dryer
Takes long to dry
Replaced control board and touch pad..up and down pads dont work normal lights dont come on...have to dry twice and still comes out damp.
  • 234 Answers
The reason the dryer takes longer to dry is due to inadequate air-flow.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Posted on Aug 10, 2009
I have a kenmore Ultra wash dishwasher Model # 665-16022400 apprx 7 yrs old-everything was working fine till xmas of 2011-then when you pushed smart wash then try to press start nothing happens-also you...
Well, Larry, it sounds as if you've tried just about everything.... except replacing the control console (with keypad), and if everything else is okay, then that is PROBABLY your problem.
Jan 09, 2012 | Kenmore Dishwashers
I am facing problem with my touch pad. it has some indicator light. while am in work with touch pad, the indicator suddenly on nad the touch pad becomes locked. its reyally frusatration to me. dont...
The button to turn the touch pad on and off can be touchy. there is not a way to adjust that either other than going to a repair shop and have it replaced. That can be a little pricey, so one less expensive way to solve your problem would be to go purchase an external mouse like you would use on a normal desktop pc. They plug into a USB port and you can then turn off the on board touch pad and still have mouse to work with.
Apr 14, 2011 | Computers & Internet
No heat dry light keeps flashing & it will not start to wash the dishes
This means one of two things. The touch pad has failed or the touch pad is locked. Hold down the heated dry button for three seconds. If that does not work, the touch pad would need to be replaced.
Appliance & Refrigerator Repair
Mar 23, 2011 | Kenmore Dishwashers
I have a gw395leps00 Whirlpool gas range. Touch pad has been erratic for about a year or so - up til now it would 'come back to life.' Now about 1/3 of the buttons don't work at all - no beep/change on...
I have replaced the touch pad on our stove twice now. The original lasted just beyond the warranty period. The 2nd one lasted about 18 months. I am on the 3rd touch pad and it is still working however this time I ordered an extra one as a backup. If you do it yourself it is not that expensive. The pad is about $60.00 at an appliance parts store. It is not too difficult to replace. Make sure the gas is shut off and the stove is unplugged! Remove the screws from the control panel and pull in out just enough to access the control board, If the burner controls are on the panel remove the knobs and the screws that connect the burner controls to the panel and leave them in place. Do not tug or pull on the burner controls! Carefully unplug the pad from the control board and unpeel the stick pad from the panel Clean the contact surface with alcohol, Carefully stick the new pad on and plug it into the control board. Screw the panel back in and you are good for about another year or so.
Jan 30, 2011 | Whirlpool Kitchen Ranges
A red light comes on my hp touchpad and I loose all control, and can't get it back. How do i re-gain controll of my touch pad?
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Oct 10, 2010 | HP P2360AA Keyboard/Mouse
Maytag neptune key pad ocassional working
The machine control pad, with the LED lights, is going out. Replace this control pad and all lights should be working normally again.
Jul 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 | Ovens
Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Jun 07, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Maytag Neptune MDG6700A Gas Dryer Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
