Question about Maytag Washing Machines
Dryer runs but does not get hot
Do I need to reset or replace my thermostat?
If so --- how do I do tht?
Thanks you in advance for your time and help
Jeff
  • 47 Answers
IT IS YOUR HEATING ELEMENT THAT IS GONE. YOU CAN BUY A NEW HEATING ELEMENT AT LOWE'S HARDWARE OR WHEREEVER YOU BOUGHT YOUR DRYER FROM. JEFF THIS IS A COMON PROBLEM IN ALOT OF DRYERS. I HELPED MY FATHER (WHO DIED IN 2006) REPLACE A HEATING ELEMENT ON OUR DRYER YEARS AGO WHEN I GOT HOME FROM WORK. IT IS THE HEATING ELEMENT. GOOD LUCK.
BEST REGARDS,
RODNEY
Posted on May 14, 2009
Roper dryer res7648kq0, replaced heat element, thermal fuse, cycling thrm, thermal kit, checked outlet, circuit breaker, still not heat, will not advance on AUTO, but will on timed cycle. Now what?
Wow.
In electric dryers with an AUTO cycle; the heater runs on 220 volts, but the timer motor runs on 110 volts. There is a resistor in the system to cut down the voltage. If the resistor is bad, you will see the same symptoms as if a thermostat was bad. The timer motor will not run in the automatic cycle. You need to make sure that you test for continuity in the resistor.
I've looked at two parts diagrams for your washer and cannot find a sensor anywhere in either, so the thermostat is what tells the timer to advance once the dryer reaches a preset temperature.
The thermostat will only tell the timer to advance if the dryer reaches the proper temperature, if you have some clogging in the vents, the dryer may never reach the proper temperature, and thus not advance on the auto cycle. but i'm sure you've probably checked that. I'm baffled. Let me know how it pans out if you can. Thanks. I'm still trying to find a wiring diagram for that model.
thanks,
Mike
Jul 24, 2011 | Roper RES7646KQ Electric Dryer
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 14, 2011 | Maytag MDE6000 Dryer
My dryer gets hot but the clothes stay moist and there is dampness on the door when you open it.
Clogged Vent
Heating Element
Cycling thermostat
Apr 13, 2011 | Dryers
Hi, i have an amana dryer that the timer and the heating element quit at the same time.could the heating problem be coming from the bad timer?
Hi and welcome to FixYa, I am Kelly
I think you have a failed cycle thermostat. The cycle thermostat provides power to the timer to advance the clock and the heating element. If the thermostat has failed it will not heat or advance the timer. Usually when just one side of the thermostat fails the timer will advance but the dryer will run and not shut off. There may a wiring problem on the C terminal of the cycle thermostat. (Burned / got hot / wire itself failed from heat )
If you can provide a model number I can probably locate he replacement parts information for you and possibly a wiring diagram.
Thanks for choosing FixYa,
Kelly
Jan 30, 2011 | Amana Dryers
Dryer gets hot and turns off
Hello there:
A lot of the times the problem lies with in the Cycling thermostat that is going out Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time If so, you need to replace it.
Next is the The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
It overheats and shuts down due to a bad thermostate Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Sep 27, 2010 | Kitchen Ranges
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
I have a Frigidaire Dryer model GLER331AS1 and one day it was all lite up with heat I had to manually turn it off, after that it will run but it wont turn off if it's not on the minutes drying time it just...
hi Gwen. I can help you.
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jun 08, 2009 | Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
