I try to power on my samsung HLR617W, the lights on the front flash, Lamp flashes in green, Timer flashes in green and standby temp flashes in red. I have replaced the bulb but the problem remains.
  • 8 more comments
  • coolpairpl May 14, 2009
    The stand by Temp light does not flash just 3 or 4 times, soon after I first turn the set on a click is heard and it flashes along with the Lamp once, a short time later it flahes once more along with the Lamp, then a short time later it keeps flahing along with the lamp and timer lights many times, I stopped at 60.
    Have tried this several times.
    I have an ohm meter, can I test the Lamp with it? if so what am I looking for>
    I don't see any fuses as you described.
    I still do not see any fuses.
    can you tell me how to test the lamp with a digital ohm meter, what settings and what I would be looking for?
    Are you going to continue helping me?
    What setting should I set my digital multimeter to and what reading will tell me if my lamp is good or not?
  • Anonymous Mar 16, 2014
    The lamp light and standby light are flashing, I replaced the bulb but the tv still will not come on
  • 749 Answers
You need to test the lamp with a ohm meter, to see if its working correctly
Posted on May 14, 2009
  • Muzzammil Ishfaq
    Muzzammil Ishfaq May 14, 2009
    i do not know what setting you will have to do this but you will need to test it.
  • 916 Answers
The clicking indicates either a power supply or color wheel problem. Since it is not turning on the power board needs to be replaced and not the color wheel.
    Brigadier General:
  • 3,614 Answers
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
Let me know for further clarifications.
  • 3 more comments
  • micromaster
    micromaster May 14, 2009
    Follow the steps below to perform a power reset:
    1. Turn off the television.
      IMPORTANT:
      For a projection TV that uses an internal lamp, wait 5 minutes after
      turning off the TV to allow the lamp to cool before continuing with the
      following steps.
    2. Unplug the TV power cord from the electrical outlet.
    3. Let the TV remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet.
      NOTE:
      If the TV is plugged into a power strip or surge protector, remove it
      from the power strip or surge protector and plug it directly into the
      wall outlet. If the issue is resolved, the problem is with the power
      strip or surge protector and not the TV.
    5. Turn on the television.
      NOTE:
      If the TV does not turn on immediately, the fan may need to finish its
      cycle. This is part of the cooling process for some projection TVs and
      is normal operation. After the fan turns off, attempt to turn the TV on
      again.
    If the issue is still unresolved after following all of the troubleshooting steps, service is required.
  • micromaster
    there could be a wrong connections inside. a possible breakdown or a faulty part resulted this problem. you may need double check the connections made. better to replace the part and put it back again.
  • micromaster
    check double-side board (the one lying flat/horizontal just to the right of
    the vertical power supply board which has the fuses) has a burnt
    transistor (the one with the sizable heat sink on it, at the back left
    corner when looking at the board from the rear of the TV). It is
    blowing the (non-power supply) fuse.
  • micromaster
    you can see it on the power board area. initially I instructed you to check also this for any possible problems on this area. sometimes failure on the power board resulted this kind of problem/
  • micromaster
    you can find it on the rear back..
2 Suggested Answers
SOURCE: Have replaced Lamp and still does same thing.
I replaced the ballast, a solution not even mentioned by the 3 Experts I was referred to.
Posted on May 15, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
May 14, 2009 | Samsung HLR6178W 61" HDTV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 11, 2017 | Samsung Televison & Video
Televison & Video Logo
1,191 people viewed this question
Top Televison & Video Experts
