Question about Refrigerators
Freezer no frost
I have GE refrigerator frost free top I have noticed frost(ice) buildinng up on back wall of the freezer
  • Anonymous Mar 19, 2014
    frost and blockage
  • 4,889 Answers
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
Posted on Oct 15, 2007
  • eagle338
    eagle338 Oct 15, 2007
    If you want help on how to use a multimeter feel free to contact me...
SOURCE:
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Back wall ice buildup, fridge not cooling but freezer is fine other than ice. Back wall of refrigerator squishes with sound of water behind it. Have had it unplugged for 24 hours, ice gone.
Anytime you have ice buildup in back of freezer it indicates that the auto defrost mechanism is not working. Check the defrost timer, heater element, defrost thermostat for proper operation.
Jul 19, 2015 | GE Profile 24.7 cu. ft. Top Freezer...
My freezer temp is at 25 degrees...WHY??
Are fans running? Any frost buildup on inside back freezer wall?
Nov 17, 2017 | GE PFS22MIS
Ice cream melted in freezer
Hello, There should be a temp adjustment for fridge & freezer adjust for colder setting. Check door sealant/gasket for cracks & seating. Next is bad news-call a BBB repair service. Good Luck.
May 12, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Frost free freezer in my frost free refrigerator
the noise is quite possibly the freezer fan cutting ice behind the wall
you may have an issue with your defrost system
Oct 06, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
I have a frost free GE fridge freezer ( freezer on top with ice maker ) Model tbx21ni There is water coming from the freezer and leaking into the fridge. What can be causing this?
cup at top ,back in the middle of fridge back wall must be cleaned. Also find other end of hose by compressor and blow in it to clear it
Aug 05, 2009 | Refrigerators
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Refrigerators Logo
373 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
