Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Our Bosch Nexxt washer uses very hot water on all
Our Bosch Nexxt washer suddenly uses very hot water on all cycles, including cold and rinse. Sounds like an internal water heater issue, but I can't find any information and the nearest 'certified' repair shop/person is 50 miles away. Anyone have experience with this?
  • renee_dej May 14, 2009
    Wow - fast! Verified model# is WFMC3301. Thanks much for the help!
    Agreed - and thank you very much for the help!
  • 15,935 Answers
There is a mixing valve that uses a solenoid to open and close (and mix) the hot/cold inlet water based on your selection.
If you verify the correct model # I can point you in the right direction for a new valve if you are so inclined.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 14, 2009
  • blueextc3221
    blueextc3221 May 14, 2009
    If your washer is the WFMC3301 as listed above...
    There are seperate valves for hot and cold water.
    The HOT Water solonoid may have failed in the open position...
    Or your controller has failed.
    CLICK HERE for your replacement hot water valve.
    CLICK HERE for the controller
    The controller management board (not shown) is the last resort... and most expensive. It would probably save you money taking it or having a service call instead of blindly changing parts without testing properly first.
    Thanks!
On the regular cycle for Bosch Nexxt 500 series, during the warm or hot cycle the washer interrupts the cycle with error code "E02" and stops washing . . . how can I fix this? I've made sure the door is...
If the unit is fed by both hot and cold it is possible that the single hot valve or one side of the double cold valve is not operating. Maybe a silly question but could one of the taps have been turned off inadvertently?
The other possibilty is that the pump filter or outlet hoses are blocked and the machine cannot empty the detergent water ready to refill with clean rinse water. To test the cold valve put the w/m on a cold wash cycle, open the drawer and check the water flow. To test the other part of the same valve, put the w/m on the rinse cycle that would take the softener or a wash cycle with prewash. Test hot valve by selecting the hottest cycle usually 90 or 95 degrees, check water flow thru drawer. Hope this helps.
Jul 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Cloths are cold after final rinse cycle ...they use to be hot
The clothes should be cold after rinses, if they were hot before, then something was wrong.
Most washers do at least 3 cold water rinses, so they should be cold, this prevents creasing.
Hope this helps.
Jan 18, 2010 | Bosch Nexxt 300 Series WFMC2201UC
WFMC3200UC washer: The setting for the cycle is cold, but the water is hot. How to correct.
Check the water lines on the back of the machine. It sounds like the water lines are reversed.
Aug 13, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
I used the cold cycle selection but I noticed that during the rinse cycle hot water was draining into the washtub. I wanted a complete cold water wash. Recognize that detergent can clog drains but I don't...
Check to see if hoses aren't reversed. Do you have an electronic temp-aaure on the unit as this could be bad as well. Also, check to make sure the valve is O'k as you could have a bad inlet valve assembly
Aug 02, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Jul 28, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water not entering machine for rinse
if the right temp water enters the machine on other cycles...it's most likely the timer...if you have trouble getting water into the machine, it's the water valves (they are actually electric solinoids) one for hot and one for cold)  also try another rinse setting on the dial.
Mar 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
471 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
