Question about Apple iPod nano 3rd Generation
My switches on my IPOD Nano will not work.
I can feel and hear the click of the switches when I press them but they will not change what is on the screen. I can use the shake feature to change songs on my playlist but I can not get any function from the menu buttons.
    President:
  • Apple Master
  • 688 Answers
I sounds like your click wheel is either bad or maybe the cable needs to be reset.
those ipods are very hard to open and i would be extra careful doing any repairs yourself.
but if you have the skills, open the ipod and unclip the clickwheel ribbon and straighten it out on the very end IE: flatten the very end.
re-insert it into it's clip and turn the clip latch down tightening it up.
then try your ipod again.
If this doesn't work replace the clickwheel.
if this helps, please leave a vote on fixya
Posted on May 14, 2009
Mp3 Ver: ld 3088 - std 1.1 does not recognized! help!
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
Feb 03, 2013 | Apple iPod nano 3rd Generation
Ipod wont turn on
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Jan 22, 2013 | Apple iPod nano
What is wrong with my ipod ao 5th generation
hope this helps
Sep 23, 2012 | Audio Players & Recorders
Ipod 2gb is on but completely frozen!
you can try to toggle the hold switch to on (red) then off then press and hold the middle button and the manuel button at the same time untill the apple logo reappears
Mar 25, 2009 | Apple iPod nano
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
Ipod quickformat and does not work
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 18, 2007 | Apple iPod MA446LL/A MP3 Player
Problem unlocking
need help lock 8gb ipod need big help now
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod 30g
  • iPod classic
  • iPod nano
  • iPod mini
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 07, 2007 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
37 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
