Question about Whirlpool Refrigerators
Icemaker no water going into icemaker - Whirlpool Refrigerators
Water valve is turned off, or waterline is blocked unit may have a screen or filter which can become blocked. remove waterline where it connects to unit,turn on water to check water flow at this point.no water, check line backward from this point to find pressure loss.if pressure is at unit connection procede checking forward for restriction . test machine.
Posted on May 14, 2009
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
Tip
Ice maker not working
This problem where the icemaker is not working properly is usually broken into sections on diagnoseing the issue of why your not getting ice out of the icemaker. One of the first things that you should check is if the icemaker is getting water to the ice tray. If you are not getting water to the ice tray then the first thing you should check would be your water filter. If your water filter is clogged or dirty you will not get any water going to the icemaker. Following checking the filter and if you still had no water going to the icemaker you would then go around the back of the machine and test the water valve. By using a multimeter you can test the two connectors that plug onto the solenoids to assure that you do have power going to the water valve. Also in some cases you may be able to disconnect the line and clean the small screens on the inside of the valve but most of the time if there is any issue with the valve it is by far easier to just replace the water valve itself. If you do have water going to the Ice maker yet your icemaker is still not working. You can also try defrosting the ice maker by disconnecting the three screws holding the ice maker in place and removeing the entire icemaker and running it under hot water. Sometimes this does help to defrost parts that are froozen in the unit. If after you reinstall the ice maker and you do have water going to the ice maker yet your unit still does not produce ice, and you can feel ice on the inside the tray and you have tried defrosting the ice maker. It is always easier and cheaper to replace the ice maker as a whole rather then buying parts for the ice maker which would cost you about Four times as much as buying a new icemaker
on May 20, 2011 | Refrigerators
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
No water flowing into the icemaker. The water is going into the cold water on the door. However, when I take the line off for the icemaker... no water comes out. I see that there are 3 connection for the...
The line to the icemaker won't have water coming out until the icemaker cycles and energizes the solenoid valve. check the inlet tube where it goes into the icemaker. sometimes this freezes shut. you can also check the continuity of the icemaker solenoid.
May 05, 2010 | Frigidaire FRS23R4A Side by Side...
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water is going to the icemaker.
Seems like the water valve solenoid is not closing the circuit to allow water into the ice bin.
Jun 30, 2009 | Kenmore 55212 / 55214 / 55216 / 55219 Side...
GE PSS23mstcss Icemaker not working
icemaker will need replaced, < only other concern with description is water dripping> would not address this unless problem did not go away after replacing icemaker, < could be leaking water valve>.
Apr 23, 2009 | Refrigerators
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
176 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
