Question about Frigidaire GLEB30T8A Electric Double Oven
  • 145 Answers
SOURCE: Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Posted on Apr 18, 2008
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
Posted on Dec 21, 2008
SOURCE: Top oven will not heat up
JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
Posted on Feb 07, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Posted on Jun 20, 2009
0 characters
1 Points
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Double oven... top works great, bottom has power but will not heat. No codes showing. Have had ohm meter on it and all is functional to elements. GE Profile model # JKP56BOA1BB, older model... maybe 1999.
Do you have 220 volts to the element. If you do then you have a bad element. If you don't then it is usually your erc (electronic range control) or your oven sensor. You need to test your oven sensor for the proper ohms, (should be on your wiring schematic), replace the sensor if you don't have the right ohms rating. You can also compare the upper oven sensor rating with the lower oven sensor rating. If your sensor is good then you need to check if your erc is sending 220 volts down to the lower oven element. Again you need to look at your wiring schematic(usually found in a sleeve behind the oven control panel), to determine which terminals to test. As always you need to be sure that you know what you are doing when you are working with live voltage. If you don't know how to work on live electical products you need to call a technician. It can be very dangerous. Good Luck, Appliance Specialists
Dec 14, 2009 | Ovens
Oven will not turn on. but stove top works fine. model#jgbs07pea2ww
A common problem is the heating element goes bad. I have had this happen and you can see a spot on the heating element which looks different from the rest of the element (a clue).
Many ovens have two heating elements. Upper and lower. Now I am no Julia Child, but I think bake turns on just the lower heating element? And broil turns on just the top heating element????
So I suppose you might have it on bake and it is not working. Might try broil and see if that works. If yes, then you are getting power through all the controls to the upper heating element, so good chance just the lower heating element is bad.
If you don't get heat to either the upper or lower heating element, then I would suspect the wiring or a control.
So far as the heating element, you should be able to remove it and using an ohm meter, get some sort of reading if it is good (I have no idea what though). Or open circuit if bad.
Also the insulation on older ranges can "melt" back exposing live wires! This is of course very dangerous and the wiring should only be replaced with high heat range wiring which I assume you could get at an appliance store?
Or the contacts on a control/switch could be bad. I would test this with a continuity tester or ohm meter.
Many appliances have a wiring diagram down low somewhere. Or might find it online.
Nov 18, 2009 | GE Profile JTP56 Electric Double Oven
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does not heat up beyond 240 degrees, which takes a long time
You have either a burned our lower element or a wire has burned off at the terminal for that element. The good news is that the lower element is cheaper.
Jan 28, 2009 | Kenmore 47783 Electric Single Oven
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Frigidaire GLEB30T8A Electric Double Oven Logo
59 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
