Question about Abit SR7-8X SiS 648 P4 ATA 133 DDR 333 LAN/ AUDIO ON BOARD RETAIL BOX Motherboard
Abit guru sr7-8x making 8 short beep sounds on start up. it was working perfectly fine then today when i started my pc it just didn't even boot up anymore. it just made the normal 1 beep boot up sound. then followed by 8 short beep sounds continuously. keep repeating 8 short beeps. please help on the issue if you know or have an idea what's going on with it.
  • ikkenom May 11, 2010
    Turn the computer off.
    Unplug the AC power.
    Remove the RAM.
    Re-insert the RAM.
    Connect the AC power.
    Turn the computer on.
    Same beeps???
    Or,
    Remove the RAM.
    Different beeps (due to having _zero_ RAM) or same beeps ???
    Genius:
  • 1,148 Answers
REMOVE THE DDR CARDS ,,TURN IT ON ,,THEN TURN OFF ,,PUT IN DDR CARDS ,,RESTART
Posted on May 15, 2009
1 long beep in post
Hello one long beep, is a failing ram module.
Try to renew the modules, or remove the modules, and insert one at the time.
Just to test one of them for fault.
4x 240 Pin DDR2, Dual Channel DDR533//667/800, up to 8 GB
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One short beep is normal.
Good luck
Jan 23, 2013 | Abit AW9D-MAX Motherboard
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Fitted 1GB RAM yesterday, computer worked fine, today started okay, but later on it had turned the power off and will not power up now (emachne 32300
If you get no power, it sounds like possibly the power supply may be bad. If you can replace the power supply with known working unit, that would be a good start. If at that point you still get no power, then possibly the motherboard could have gone bad. Even without the ram installed you should get power through the board and when you try to boot you should get a beep or series of beeps. I would start with the power supply tho.
Sep 24, 2011 | E-Machines eMachines Refurbished EMA...
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
Feb 06, 2011 | Abit AV8 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
Abit Fatal1y FP-IN9 Boot Problem!?
check your jumper settings. You can probably view jumper diagram online. Make sure all drivers are downloaded and up to date. Try placing windows installation disc in before booting pc. Also check boot setting to make sure hardrive boots second and cd boots first. Also make sure your hard drive jumper is set to master.
Jul 02, 2009 | Computers & Internet
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Abit SR7-8X SiS 648 P4 ATA 133 DDR 333 LAN/ AUDIO ON BOARD RETAIL BOX Motherboard Logo
442 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
