Question about Toshiba Satellite 5005-S504 Notebook
Pop up message says that I have a USB device that is not recogniz
Running Win XP Pro. All updates. Message pops up apparently at random. I have removed and reinstalled Root Hub drivers. message cvontinues. If I need a USB 2 device I connect it via a USB 2 PC card. How do I get rid of this annoying problem. Device manager shows a generic USB 3 port hub where one port is unknown.
  • 700 Answers
Will I think you plug or installed a usb bluetooth device. Or usb soundcard, or infrared device. But commonly its a usb bluetooth device.
Will to get in stop. Try to uncheck it in startup on msconfig. Or run the software for it and set it not to run during startup.
help it helps or give you an idea.
Posted on May 14, 2009
  • 114 Answers
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
I wany to know how to take picks off my computer and put picks on my android 2.2 xps m1530 dell lap top
To transfer pictures from your computer to your Android 2.2 device, connect the Android device to the computer by the USB cable. This should pop up a "USB connected" message. Click the Turn on USB storage on the Android device. If this doesn't show up, you might have to pull down the top notification bar on the android device and select "USB connected" first.
Once you choose to turn on USB storage, you will get a message asking you to confirm, as it can cause running applications to crash if they need to use the SD card. Select OK once you have confirmed you have no running applications that need the SD card.
After a few seconds your computer should have recognized it and pop up a message asking you how you want to use the device. Select view folder. If it doesn't pop up, you can always go to My Computer and open the drive named after your Android device.
To copy the files simply drag them from their current folder to the folder you want them to be in on your Android device. Please pay attention to the symbol on the file icon as you drag, as depending on system settings you might be either moving or copying the files. Shift and Ctrl will toggle this setting to the other one before you release the mouse while holding them.
Please leave feedback if this was helpful. Thanks.
Mar 21, 2011 | Computers & Internet
New device not found/ usb2 power overload message on the screen, i unplugged the tv and it does not solve the problem. I have looked at manual but its not answered in troubleshooting.
I called 1-800 SAMSUNG and they had a firmware update that fixed the problem. I don't know if the update is available on their website, as I had downloaded a firmware update 2 days previous and this was a newer version that they sent me via email.
Oct 09, 2010 | Samsung LN55C650 TV
ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Oct 20, 2009 | Logitech ClearChat Pro USB Headset
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
T40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Sep 14, 2008 | IBM ThinkPad T40 2373 Notebook
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Desk top APC UPS ES750 not communicating
Here is an answer I got from APC when one of my client got the same problem as you did:
The error message would pop up if the link between the computer and the UPS is weak. I cannot rule out a problem with the cable or the UPS. In order to confirm the same please try the following steps which might help :
1) Ensure that the USB cable is properly connected to the USB port of the computer.
2) If the PC was powered on before the UPS, communication will not be achieved until you disconnect and reconnect the USB cable to the host. In this case, you need to disconnect and reconnect the USB cable to establish communication.
3) Some other software is polling your USB port for another device, thus causing the UPS software to temporarily lose communication with your UPS. If this is the case, you would need to shut down that application.
4) If you have any other USB devices connected to the PC, disconnect them and then try plugging in the cable.
If the issue persists, please visit the following link which lists few troubleshooting steps :
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=oXhRFGEh&p_lva=&p_faqid=2923
Dec 13, 2007 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
Toshiba Satellite 5005-S504 Notebook Logo
195 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
