Question about HP Pavilion dv5-1000us Notebook PC
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Computer screen froze yesterday and had to turn off by unplugging and removing battery. Restarted and only got black screen and 3 beeps in endless loop. Fan working. How can I restart the computer?
  • 191 Answers
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
Posted on May 14, 2009
  • 2 more comments
  • Frank Zhang
    Frank Zhang May 15, 2009
    is this help you fix it? please rating me thanks! any question? please
  • Frank Zhang
    ple!ase take a rating let me know how much helped you? thanks a lot
  • Frank Zhang
    Frank Zhang May 20, 2009
    please take a rating let me know how much helped you thanks!
    keep in touch your question please.
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks
  • 20 Answers
3 beeps iin loop means video failure.
Video can not be initialized.
Need the graphic cipset to be reballed/replaced(sometimes).
So mr frankzjm stop calling yourself hp guru.
I have no ideea about problems.
Memory failure are usualy represented by long beeps continuously for hp laptops.
Posted on May 06, 2010
  • yngwei50
    yngwei50 Sep 13, 2010
    Is it 3 long beeps?
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
Sometimes when I start my HP pavillion dv5 2135dx laptop the screen is dark even though the computer is up and running. It may take several shutdowns and startups for the screen to finally come on. Other...
If you can very vaguely see the icons or pictures displayed on the screen even though dark it maybe either a problem with your inverter or Lcd backlight. If no images are seen even though you look carefully then it may be the onboard vga controller. It maybe worth checking to see if your laptop is under warranty with Hp see link.
h10025.www1.hp.com/ewfrf/wc/weInput
I
Feb 27, 2011 | Computers & Internet
Hi there I have a HP pavilion DV5-1250us. When I turned it on sometimes it didn't start up at first and the capslock and numlock leds were blinking in loop. I needed to restart it to start up. But...
Hello, Try to unplug AC charger, remove the battery and keep press the power button for 1 minute. after one minute, connect the battery and AC charger and start up the system
Aug 03, 2017 | HP Pavilion dv5-1250us Notebook
Dear sir. my laptop hp pavilion dv5, its comming
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 27, 2010 | HP Pavilion dv5000z Notebook
Problems with HP HP Pavilion dv5-1159se 15.4
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
3 beeps then black screen after boot
Depending upon the BIOS manufacturer, 3 beeps usually mean you have RAM problems, the RAM may need reseating to get proper electrical contact or the RAM may be faulty. Reseat the RAM module/s then reboot the computer. If this didn't solve the problem, remove the RAM and insert it into another computer to test the RAM, if this is not possible, take it to your friendly computer shop and get them to test it for you.
Jun 09, 2009 | HP Pavilion dv2000t Notebook
How to attach the Battery in the new HP Pavillion DV5 computer
Generally, laptop battery to bottom both have a wedge, it's fastness battery to bottom. you must find it. can it's glide or draw , find lt, use hand to glide or draw , encase battery in X axis is OK.
hope can halp you.
if don't contact me: lincen18213@163.com
Apr 13, 2009 | HP Compaq Presario F750US
HP Pavillion dv4000 cto won't start
Hey,
if the computer doesn't beep at all, and noting comes on the screen.
Lets do this first,
Remote the ram from the computer, start up without ram.
turn the laptop off and unplug, did you hear beeps?
Place the other memory module back in and try starting up.
if the computer starts up then all is ok you can plug in the other ram and start up again. if it doesn't start up then repeat the previous process.
if this has no effect and you don't get any beeps from the computer the motherboard most likely has a problem.
I would suggest you call hp or your dealer to check your warranty.
If you are outside of warranty the repairs will cost you.
Discuss repairs with hp and see if its worth it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | HP Pavilion dv4000 Notebook
Laptop will not boot and screen is blank
3 beeps means the RAM or memmory problem, check it by yourself or consult to a technician.
Dec 17, 2008 | Computers & Internet
HP Pavilion dv5-1000us Notebook PC Logo
3,807 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
