Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Ed2shaxm freezer not working refrige side works
Freezer not working fan is running but temp is only 50 degrees in freezer all food defrosted
  • Whirlpool Master
  • 4,654 Answers
Need you to have a look at a few things inside the fresh food compartment. Also go to site listed below and enter model number
ED2SHAXML10 into the model search feature. This will take you to the page and on left side of page choose photo #11 controls. this is what I want us to focus on unless there is other symptoms not mentioned in your post. Part number 6 and # 9. Let me know, Thanks, Sea Breeze
Posted on May 14, 2009
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Bottom not cool at all
Greetings,
The first thing to check is are all the fans running? there is one in the freezer and usually one in the rear compressor compartment...the next thing to check if fans are operating is: remove rear freezer panel and see if ice or frost is blocking the air thru the freezer coil...if there is ice blocking the airflow. defrost the coil using a hair dryer.. the fresh food section gets cold air from the freezer..its blown over into top of refrigeration via a fan...it goes thru a baffle into refrigerator...this baffle sometimes will not open...This is one place you check for air coming into refrigerator...so, check here also before you take it apart. there should be a noticable amount of airflow....if not, remove the cover and work a small wooden dowel or skewer into the slot and open the vent..this will allow air to go into refrig section...the skewer can be left in there to keep it working if this is it...getting back to a frosted evap...if it is froze up..there is a derfost problem and defrosting will give you temp service until you can get it repaired......Bruce Denton
Jan 09, 2011 | Whirlpool ED2SHAXM Side by Side...
Refrigerator temp not going below 50 degrees
You have one of two different problems. Either the fan in the freezer side is not running/working or you have a defrost problem. Check on the freezer side to see if you can hear the fan running, and if it is, look on the back freezer wall for a build up of ice. If you have that, one of the components of the defrost system (timer, defrost thermostat or defrost heater) is bad. List your brand so I can be more specific.
Jul 08, 2010 | KitchenAid KSRB22FNSS Stainless Steel
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Side by Side Refrig./Freezer ices up and shuts off
Good day,
You said it was iced up. That is an indication the defrost system is not working. The thermostat (round Disk??) if it popped out is probably due to swelling. Replace it.
Since the machine is empty, unplug and leave the doors open for 24 hours.
1. Air sensing thermometers will rise rapidly when the door is open. Not a trusted method.
2. The compressor will not run because you open the door. there is a time delay for refrigerator thermostats to react.
3. Leaving it unplugged with the doors open will guarantee that hidden ice in supply and return chutes has completely melted. IMPORTANT.
Below is a good tutorial on defrost systems.
Hope this helps , but if you need to post back please include make,style and complete model number.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa and
please rate me.
Jack.
Jan 06, 2010 | Refrigerators
Roper RT18SKXRD01 top/bottom refrigerator. Freezer fine but refrig isn't cool (50-degrees). took off back panel in freezer and fan blades not going around (they move freely when I spin them manually)....
The most likely problem is in the Adaptive Defrost control part number 4388931 I recommend that you unplug the refrigerator and examine this part first. If not here then we need to check the defrost heater and defrost thermostat. Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jul 05, 2009 | Refrigerators
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
128 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
