Question about Kenwood KRF-V5060D Receiver
Music, sound effects no dialogue
I have a Kenwood KRF V5200D running with optical to PS3. After finally installing rear speakers, DVDs can't be heard in Dolby Digital - you can hear the sound effects, music but not the dialogue. Can hear everything perfectly if select stereo. When playing Blu Ray disc could hear everything in Pro Music but would not detect DD only Pro Logic. Any suggestions?
    Genius:
  • 1,148 Answers
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
Posted on May 15, 2009
Sounds ok but not dialogue...
It sounds to me like you are using the receiver in surround sound mode and the click you hear is the center channel turning off. If you have another center channel speaker, try swapping that for the one you are currently using. If that doesn't fix the issue, then try replacing the speaker wire. If that still doesn't fix it, then the issue is probably inside the receiver and may be either an output transistor that is failing when hot or an electrolytic capacitor that allows too much DC offset when hot.
Oct 10, 2016 | Kenwood KRF-V5060D Receiver
Connecting ps3 receiver
buy a optical cable and connect between PS to the amplifier or take the optical out from the TCL to the amplifier and select optical in,
Oct 19, 2013 | Kenwood Audio Players & Recorders
Reciever keeps yurning itself off after a few seconds
Assuming running from a cold start,
it means protection circuit are activated.
If it runs hot, then turns off then it is thermal cause.
Simple solution could be disconnecting all your speakers
and power up.
If it runs OK, then reconnect one at a time to find the cause.
If disconnecting the speakers doesnt do anything,
these unit needs repair.
Start checking out power supply
Check the supply rails to the main amp ( B+ and B-)
and most important , check for DC offset voltage on all amp outputs.
Let me know if you need further assistance!
Sep 27, 2012 | Kenwood Audio Players & Recorders
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
I have a brand new kenwood krf-v5200d amp. when I turned it on the first time it when't straight to the standby light blinking. I have checked all speakers and they are connect correctly. Any idears
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
Nov 29, 2008 | Kenwood Audio Players & Recorders
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
Increase AM bandwidth to 531khz to 1700khz
ya am booster antenna of the am output u could try 1st or u saying teh kenwood limites u to 1620 max only ch >
Jan 23, 2008 | Kenwood KRF-V5060D Receiver
Kenwood KRF-V5060D Receiver Logo
483 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
