Question about Technics RS-TR373 Single Cassette Deck
Making copies? I can't seem to make 1:1 copies of a tape or create samplers. Whenever I push record and play on the right player, the left player stops. It doesn't matter if I use Synchro Start or Auto Rec Mute, the left player always stops at the exact moment the right player starts recording. The solution is probably a simple one, but I'm at the end of my wits.
  • 1 more comment
  • azbera Nov 13, 2007
    I have an TC-WE475 which won't record at all. We've read directions, checked to be sure all tapes were appropriately tabbed and as they should be. My father bought this deck in 2001 and he never was able to make a tape on it either. It plays beautifully, it gives you an old tape nicely cleaned of the material on it and the new tape is just as clean as when it started. Any suggestions, any one?Thank you.
  • Anonymous Mar 09, 2008
    seth came
  • joshuasuzy Jul 26, 2008
    Yes and the right side "record/play" drive will not record anything alone! The only difference I would indicate is that the product is a stereo double cassette deck not a single drive!
    What was the finding ,solution ??
    Thank you,
    joshuasuzy
Where...Cervice central office in indonesia..my phone 08568957867
Deden S Depok Indonesia
Posted on Jun 12, 2008
Where ....cervive central office in indonesia ?
Oh yes, on the TD-WE375 above the left deck also stops playing sound when the right deck is readied for recording.
Posted on Nov 13, 2007
SOURCE:
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Play back/recording of tapes
check the conections if some where loose.
Aug 25, 2008 | Audio Players & Recorders
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to set up to copying a video tape.
This is a snap, as long as you have a second VCR if not you can't do it.
1. Hook the out put line(s) from VCR1 to the input line(s) on VCR2.
2. Put recorded tape into VCR1 and press play.
3. Set VCR2 to the channel that VCR1 is playing on, it's usually 3 or 4.
4. rewind the recorded tape and put the blank into VCR2.
5. Press record on VCR 2 and play on VCR1.
if you want an exact copy stop here. . . or
6. pause VCR2 when ever something comes up you don't want to record, ie a commercial if you'r re-recording a movie from TV. be for warned though each time you re-record an analog recording, like a VHS tape, the audio and vido tracks get further and further apart. After about the second or third time you re-record a tape you'll hear something before you see it, or vice-versa. I hope this helps you out.
Dec 24, 2007 | Emerson EWD2202 DVD Player/VCR
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Technics RS-TR373 Single Cassette Deck Logo
234 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
