Question about Zebra P330i Thermal Card Printer
My Zebra S4M does not print data on center of lable, always pushes info to the right hand side and cuts off half the info
    Problem Solver:
  • 18 Answers
You need to do a reset on the printer. Call BarcodeWarehouse.biz - they will walk you through it for free.
Posted on Sep 19, 2009
    Problem Solver:
  • 9 Answers
Adjustment should be in the software
Posted on Aug 31, 2009
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
Hi I have Zeba printer S4M It is printing from half side
mohd shah521: Adjust the page label size in driver parameters to match the real label.
Roberto Martinez
padrino99@prodigy.net.mx
Aug 22, 2011 | Zebra S4M Thermal Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Is it possible to import data from excel into the labelprinter Zebra S4M?
You can print a text from XL, but you owuld have to use a page set up that is the same as the label size, through a Zebra or Seagull driver.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
When printing from a Zebra TLP 2844, text is getting cut off. I am printing from internet software, center aligned. If there are too many characters, the text is getting cutoff on either side (I would say...
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Apr 27, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My Zebra LP 2844 printer is not aligned and the info on the tag prints onto the next tag, how do I fix this?
Calibrate the media that is in the printer. Power the printer on while holding the feed key. When it flashed red, let go. It will calibrate, print a config label, then go into dump. Press the feed key again to exit dump. Once this is complete, your printer should advance only one label at a time when you press the feed key. If this is working as expected, but the labels are not printing right when you print from you application, there is a problem with your format or driver settings.
Jan 07, 2010 | Zebra S4M Thermal Label Printer
Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
Zebra P330i Thermal Card Printer Logo
472 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
