Question about Philips DVDR3320 DVD Recorder/VCR
I have a dvp3055v
When programing a show where does it ask u what channel u want to program
  • 790 Answers
What do you mean sir? can you tell me the main problem of your unit? thanks!
Posted on Oct 16, 2007
GDB1225DTfreeview+DIgitalTV Recorder.
Check your schedule
This happens if you've asked the box to record more than on episode
For example on Channel A , channel A + 1 and Channel B that shows same program at a different time
Oct 27, 2016 | The Video Cameras
Cant get my Kenwood Tk-2312 to change channels?
I hate to ask, but who programmed the radio? It may only have a single channel programmed. If new, contact your dealer, if used, find a dealer. If bought from a warehouse/online, find a dealer. They do not come with 128 channels programmed . Not a consumer radio, it is designed for police, fire and business.
Jan 17, 2016 | Kenwood Radio Communications
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
I need to record a cable show on to a vcr? how do you do it
I doubt you can do what you are asking. There are technical reasons, based on changes in television technology. Unless you understand the issues/technology, you would not be able to answer my questions.
If the output signal of the Cable TV box was NTSC (without copy protection), then you would be able to record the program on an NTSC VCR. Very unlikely at this time.
I suggest you buy a Digital Video Recorder, like the one Channel Master makes, and record your shows via a TV antenna. Over The Air OTA DVR 16GB Channel Master
Oct 23, 2017 | Sharp VC-A412U VHS VCR
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
I need help programming vcr to tape show
Since the V9800 has no built-in tuner, your TV set must be set to the channel your show to be taped is on. There is no way to tune it to any particular channel. Now, isn't that convenient?
Feb 16, 2010 | Samsung DVD-V9800 DVD Player/VCR
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Philips DVDR3320 DVD Recorder/VCR Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
