Question about Avaya Lands Phones
Copy settings command #399
I tried to use the #399 command to copy the settings from an existing phone (extension 13) to a new extension (extension 21).
The command asks for the source extension which I entered and then it asks for data. I entered 21 and tried pressing different programming keys to get it to finish the command but nothing seems to work.
Any ideas?
  • moserdw Oct 15, 2007
    This is for an Avaya Partner ACS system
The only thing this will copy is line information. Not buttons.
Posted on Jun 13, 2008
"Set unavailable" error received when I tried to Set Copy on Norstar M7310 phone
Are you sure you have the correct extension number for the destination? I may be more than "not progammed correctly" - perhaps it isn't the ext# you think it is. Try Feature*0 then all the keys, especially the line keys, which should give you the extension number.
Apr 21, 2015 | NorStar M7310 Corded Phone
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Tip
How to hide files in a jpg photo
1) Take two files -
one which you want to hide and another will be the jpg image(of any size and dimension)to hide that file
If you want to hide multiple files in one jpeg image, just zip them into one file
2) To make the process easy, Copy the above two files to the C:
3) Now open the command prompt (Go to start, Click "RUN" and type "cmd").
4) get to the root by typing cd\ or you can give the path name where the files are located
5) Now type the following command:
copy /b imagename.jpg + filetohide.ext new_image.jpg
6) Now a new file new_image.jpg will be created
7) Double click on the file and it will open the image which you used to hide the secret file
8) To access the hidden file simply change the extension from jpg to orignal extension of the hidden file,
Example: I took an image filename "myphoto.jpg"
I wanted to hide some important word documents so I zipped all the word files and created a zip file "word.zip"
Then copied both "myphoto.jpg" and "word.zip" to c:
Opened the command prompt
Typed the command: copy /b myphoto.jpg + word.zip new_image.jpg
Now I have a new file "new_image.jpg" in C:
When I double click on the new file it shows me the image of "myphoto.jpg"
If I change the extension of new_image.jpg to new_image.zip I can extract the contents of the .zip file
ENJOY !
ENJOY !
on Dec 03, 2009 | Computers & Internet
I cannot ring other phones in our office and my phone doesn't display when other employees are on the phone
Hi Kym,
It sounds like your phone might be a bit of a lone ranger! Try cloning someone else's phone settings to your phone and see if that solves the problem for you. You can do this by:
Feature **266344
Password: 266344
You should see Terminals and Sets. Press the Show button.
It should ask the for extension number, so enter the extension of someone whose phone is working properly.
Press Copy
It'll say "Copy SystemData" Change that so that it copies subscriber as well.
Press Next. It'll say Copy Single. Press Next
Enter your extension number when it says Copy to:
Once it has finished, hang up and give your phone a try once it has updated.
Jan 14, 2014 | Nortel T7316E 2-Line Corded Phone
How to transfer files from one partition to another using dos command?
hi if you wont move command
then try
go to the source dtive
[ example c: ]
then
move filename sorce_address source filename dest_address destnation_filename
example c:\>move text.txt d:
if you wont copy use copy insted of move
if you wont copy/move all files
then
c:\> copy *.* d:
if any problam replay me
May 02, 2011 | Microsoft Windows XP Professional
I can not call localy ( inside the country)
Check #401 to see if its on 1- no restriction or 3- local only
Sep 06, 2009 | Avaya Partner 34D Corded Phone
I have downloaded a folder to the usb drive and now i have added more files ( pictures ) to the folder. how do i now download the new files o the usb drive without adding the pictures that are already...
open a command window at the source folder
try a DOS command like this,
long line may wrap
replace the [usb*] with the spec for your system,, filespec can be anything, *.jpg *.raw that your camera requires
for %f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%f copy %f [usbdrive]:\[usbfolder]
or you can make a batch file to do the same thing as this is likely to be a repeated task
@echo off
cls
echo Copying New Files
for %%f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%%f copy %%f [usbdrive]:\[usbfolder]
echo New files Copied
Nov 02, 2008 | Computers & Internet
M7310 phone buttons
Wow, you should get 2 lines and at least one intercom by default. Lines are assigned in most Nortel systems in Terminals & Sets. Your COPY command is your friend. Just pick a phone you wnat to emulate and copy it to your new set.
Carl
Sep 01, 2008 | NorStar M7310 Corded Phone
Dos Problem
If you are only trying to move your data file, then create the new directory using the cd command e.g.  cd test.  Then move the file to the new directory either using the move command or the copy command eg. copy test.file c:\test\test.file
Alternatively you should try using the old text editor program in dos to load your file and then save to the directory of  your choice.   good luck
shane67
Mar 03, 2008 | Computers & Internet
I can't get the voicemail button to work
You are describing two different things. The "speaker 43" is the default code for Busy/No Anser Set. The correct syntax should be Speaker - 43 - 399 - Speaker. That should set CFWD B/NA to VM. Next, if you have a button programmed to call VM, it is probably a speed-dial or one-touch button. It would have to be programmed to dial 399. If that is not working, try calling VM (399) and make sure you can get into the box that way. If that works, but the button does not, press the Feature Key and the button for VM. It should display what is programmed for that button. If it needs to be changed to call VM, the syntax is: Feature - Redial - the button to program - "1" - "399" - Feature.
Feb 07, 2008 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
239 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
