Question about IBM ThinkPad T21 Notebook
Toshiba M400 Battery 100% but when power disconnetced shuts down
I have a Toshiba M400 running VISTA
The Batty is reporting 100% Charge and the yellow charge light comes on when I unplug and replug in the battery. Then it turns off.
If I disconnect the mains power the system turns off. Crash.
Could the battery be at fault or the motherboard or Power management driver?
What tests can I run?
  • 2 more comments
  • Anton Snadoks May 14, 2009
    Thanks I am aware of that. I guess i need to borrow a battery that I know works first and see if that solves my problem.
    The computer boots and runs OK on mains. before i updated to VISTA the battery charge light would show it charging and then trun Green. Now the battery light just turns off. If I unplug battery and replug the battery light comes on for a while and then 2 minutes later the Battery light will turn off.
  • Frank Zhang
    Frank Zhang May 11, 2010
    how long the battery used?
  • Frank Zhang
    how ling the nattery used?
  • 431 Answers
Hi I am Vortash .. firstly take the battery out entirely then put your adapter in and boot up if the charge light is off you can safely assume the computer is fine .. batteries have a shelf life and an internal memory , they tend to do strange and wonderful things when they reach old age lol one of them is telling lies it says it's full when it's empty .. you will probably find a cheap replacement on Ebay or Amazon and I think you will find that will cure your problem .In the event the first test was a bust and on your computer the charge light still came on .. then you should take it to a service department for a free estimate they will tell you whats wrong and if you don't get it repaired there you can ask on here how to repair it ?. regards vortash
Posted on May 14, 2009
Battery
This is the procedure for solving consider replacing your battery problem. Start by running the command prompt with administrator privileges. This will give the full control over the command prompt. There are those commands that can only be executed when you are using the command prompt with administrator privileges. Change the destination path showing on the command prompt to be set to C:\ then type the command POWER -ENERGY( to change destination path to C:\, type CD\ ). This command will make the computer scan the battery status and after 60 seconds, a report will be generated and saved in C:\. Simply open the energy report and scroll to check the battery information. Look for the design capacity and the last full charge, note the difference in this figures.
For my laptop, these were the details
Battery Information
Battery ID: Hewlett-PackardPrimary
Manufacturer: Hewlett-Packard
Chemistry: LION
Design Capacity: 88800
Last Full Charge: 36467
To remove the message consider replacing battery fully charge your laptop battery then unplug the charger to use the laptop on battery power. Use it until the laptop to automatically shut down. Still with the charger unplugged, power on the laptop again. Do this until the battery is totally empty. Now plug in your charger and charge the battery fully. Then perform the commands steps again by running the POWER -ENERGY command. Make sure you note the differences in the last full charge details. Continuously perform these steps until the figures in the last full charge are more than 40% of the design capacity.
May 19, 2013 | Acer Aspire Notebook
My Toshiba nb505 netbook run with the AC adapter, but will not run on the battery. The battery shows that it is charging but the charging percentage does not increase. Any advice?
I own the Toshiba NB505 netbook and the very same thing was happening to me. Here is what I did to fix my issue:
Step 1: Shut down the computer and remove the battery. Then turn it on but now with the battery out. It should say "battery not detected".
Step 2: Open control panel and open the "device manager". Under "batteries" (the first one), uninstall the one that says "Microsoft ACPI Compliant Control Method Battery". This is the battery driver.
(Don't worry. The computer will automatically re-install it)
Uninstall the driver and shut down the computer.
Then reinsert the battery and power on the computer. The driver should have re-installed itself. Check to see if the battery is now charging.
(It will take awhile for it to fully charge to 100% Best to shut it down and let it charge. The far left indicator light on the front of the Netbook will turn green when it is fully charged)
Hope this helps. Yeah I had to figure this one out on my own. Toshiba support staff over the phone were useless!
Good luck!!
Sep 24, 2012 | Toshiba Turquoise 10.1" NB505-N508TQ...
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
My Portege M400 will not turn on with the battery installed. It will work if you remove the battery and use the power supply. The power light only blinks yellow while the battery is installed. I have tried...
You look very much the unlucky owner of a busted battery.
I'm afraid the battery will have to be replaced. Meanwhile, do not use it with the power supply; not only it will do no good, as you already determined, but it might damage the power supply itself.
Jan 03, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba M400 Battery 100% but when power disconnected shuts down
hi dear i dont think you can any test on this my addvice is take to toshiba service center ...
thnx
May 14, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege M400 to Vista
Here's a link for Toshiba's UK site. I looked around a bit and they don't seem to offer much in the way of drivers. You might try driverguide.com I've found it to be a good place to find those hard to find drivers, plus it's easier to use than most manufacturer's sites.
http://www.toshiba.co.uk/
Jul 04, 2008 | Toshiba Portege M400-S4032 Notebook
My Vista Laptop immediatly shuts down after i pluck out the power cable.
It sounds as if the power pin (where the AC cord connects to the computer) has been damaged. The part to fix it usually runs under $10 but the labor is gonna set you back $100-200.
Because the connector pin is so fragile, the damage to the pin is caused by the day to day tugging and pulling on the power cord.
What you needed when you got the computer is a cable stay or cable retention device like the Jerkstopper. It takes up the strain when you yank or **** the power cord and minimizes the damage to the power pin. It's a very common problem with laptops.
Here's a short video that talks about the problem. . . .
Apr 20, 2008 | Toshiba Satellite 2410-S203 Notebook
IBM ThinkPad T21 Notebook Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
