Question about Honeywell Programmable Thermostat Heater
Brivis buffalo 85 will light & go out seconds later. Will do this 4 times then give up. Will do this again when power point switched off & on at furnace.
  • easternheat May 15, 2010
    Hi depends on what date of manufacture 1992-1999 could be control box 321 problem 1999-2008 could be flame sensor/ignition module do any flashing leds indicate anything
5 Suggested Answers
SOURCE: Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Posted on Nov 08, 2009
SOURCE: Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Posted on Jun 12, 2010
  • 43 Answers
SOURCE: Pilot lights up but would
This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
If the pilot turns on and the gas ignites, then shortly after the unit shuts off, chances are this is your blower motor. It is not starting up, then the heat limit is reached in your unit and the safety shuts it off.
Posted on Mar 02, 2011
reyjoshua07
  • 1157 Answers
SOURCE: brivis buffalo 85 EMS .
Hi redrosebulld,
If the EPRL light still flashes most likely the thermocouple has worn out. The thermocouple is a safety device which stops the gas from flowing. I will recommend to consult an authorized repairman to check the thermocouple and also the injector.
Hope it helps.
Thank you for using FixYa.
Posted on May 20, 2011
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
Buffalo 85 fan not blowing
sounds like the fan is not working, can you isolate the fan and run it by itself with out the burned, this will tell you if it's the fan motor or some sensor that's the trouble
Apr 28, 2013 | Heating & Cooling
Brivis Buffalo 15 not blowing air.
This sounds like a flame proving fault, so what's more than likely happening is the unit isn't sensing the flame. You'll see a small metal rod sticking down infront of the burner on the opposite side as the ignition source. Remove that rod, and clean it with some scotch bright. If you know how to work a volt meter you can test this part. Take the wire off the flame rod, place your meter leads in series with the wire and flame rod and set it to micro amps DC. Fire the unit up, and when your main burner lights you'll want to see a minimum of 1micro amp DC. If you're getting a higher reading than that and it still cycles I'd be suspicious of the grounding of the burner, or the ignition control! Good luck, let me know if you need any more instruction!
Apr 18, 2013 | Heating & Cooling
How to turn on the brivis buffalo 52
Refer the user manual given below to setup your Brivis Buffalo 52 and start operating it:
Brivis_Manual
May 28, 2012 | Heating & Cooling
Sep 22, 2009 | Heating & Cooling
Brivis buffalo 85 with EMS2 would not fire up
Hi Long Bob
I am having the same problem. Did you find out what was the cause?
Cheers
Chris
Jun 30, 2009 | Honeywell Programmable Thermostat Heater
Jun 11, 2009 | Heating & Cooling
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Heating & Cooling Logo
320 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
