Question about E-Machines eMachines Desktop PC
Display resolution stuck at 640 by 480 pixels? please help
I am having some problem in adjusting my desktop’s display settings. I have reinstalled windows XP home edition and installed all the drivers including video card drivers. But my display settings just stuck at 640 by 480 pixels. I tried to adjust it at little bit higher settings , I tried at 800 by 600 pixels, 1152 by 768 pixels and higher but when I hit apply in display properties it keep on coming back at 640 by 480 pixels. I checked video card properties and it shows its working okay and have no confliction with any other device These are few things I tried so far but nothing helped.
1) I uninstalled video card drivers and installed it again
2) I tried another video card on PCI slot
3) I tried to change adaptor settings in display properties
4) I tried uninstalling all other devices like sound, Ethernet and wireless drivers but nothing seemed helping
Could anybody please tell me why its happening and how can I fix it. If you need any more details please let me know. My motherboard is Foxconn and it has integrated SIS FX661 pro video card. I tried Nvidea video card on PCI slot but got same problem.
Thanks in advance
  • Varinder Dhindsa
    Varinder Dhindsa May 14, 2009
    could you please tell me how can i save display resolution
  • 12 Answers
SOURCE: VGA doesn't work on my EMachines W2040
Test your system with another monitor. The problem could be your monitor. Hope this helps......
Posted on Sep 26, 2007
SOURCE: RELOADED XP
yes, install new drivers, ****.
Posted on Feb 21, 2008
  • 1019 Answers
SOURCE: Sound Card "This Device Cannot Start"
the soundblaster cards, usually have to set an interupt port IRQ.
This can sometimes conflict, with any other device connected i.e printer/paralel port.
I,d suggest, power off the computer. and remove the mains power cable. then completely remove the soundcard.
either try the card, in a different pci slot, if you have a spare.
or reboot the computer, without the card in at all.
shut-down, power off. re-insert the card and re-install.
also check, the on-board sound card is working correctly if applicable. you may have a conflict between the on-board and standalone ( soundblaster Card ) attempting to share the same driver or resources.
Finally check the motherboards jumper settings ( User Manual ) to enable/disable the onboard sound. if necessary.
And check the settings in BIOS.
Mike @ compurepair.
Posted on Jul 02, 2008
jell587
  • 447 Answers
SOURCE: No Sound on Emachine T5048
Download the Realtek HD driver from here, re-install. Should fix the issue.
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: Need windows XP drivers for eMachines t3616
google: nvidia nforce network management. This will take you to
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
You can then download the driver for you network adaptor which will then get you into the internet where all things are possible!
Posted on Oct 12, 2009
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
Text to small
Change Your Font size.
1.Right Click on Desktop Click Properties "Display Properties will appear".
2.Click Appearance Change Font Size to Large Fonts or Extra Large Fonts.
3.Click Apply and Ok.
Or
Adjust Screen resolution.
1.Right Click on Desktop Click Properties.
2.Click Settings Adjust Screen resolution to 800 by 600 pixels
3.Apply and Ok.
Aug 13, 2011 | Computers & Internet
I have an AMD athlon processor. I want to set my screen resolution to 1920 x 1080 (Full HD). But in Properties --> Settings, this option is not there. My monitor's native resolution is 1920 x 1080....
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
May 24, 2011 | AMD (axmd2400fjq4c) Athlon XP 2400+, 1.8...
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
When in gmx,letters are too large .How do I set the display back to normal.
right click on the screen then select properties..while on display properties click settings..under the screen resolution, adjust the slider bar to the right until the pixel is 1024x768..adjusting to the right decreases the pixel and to the left increases the pixel.. under the color quality select highest (32 bit)..click apply then OK..when prompted to keep the settings click OK..
Jul 19, 2009 | Acer Computers & Internet
Dear Sir, I am sarjad i have one pc of windows XP there is slight problem regarding with display setting . i want to change my display setting please give me a currect way. my screen resolution is 1280 by...
the resolution depends on the VGA card you have & the display or monitor you have. if you are given by default some modes those are the best suitable for viewing. any way can if you can let me know the motherboard model, VGA card model & Monitor you are using. i might be able to give you some help
Jan 20, 2009 | Computers & Internet
Screen
Right click anywhere on your desktop (not on an icon), *Properties, *Settings, under "Screen Resolutions" slide the marker to the left until you get what you like. This is the simple way to do it.
Jul 04, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen resolution
you will need to reinstall your video/display drivers and make sure you download the correct ones for the site. (toshiba's site).
Jun 19, 2008 | Toshiba Equium 6200M (PV1026U-01A) PC...
E-Machines eMachines Desktop PC Logo
189 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
