Question about Nokia 6133 Cellular Phone
Phone "menu" key dials 9
I dropped phone in dog's water bowl. It spent about two seconds there. Everything still works on phone except the menu button does the same thing as the 9 button. Is it fried and I need a new phone? I hope since everything else works there is a way to fix it. I like the phone and don't really want to get a new one. Thanks
  • 431 Answers
Hi I am Vortash you could try this not promising anything but it worked on other phones I have had that have been soaked .
Remove the battery cover and the battery also remove sim .. wrap up in a tea towel and leave by a radiator over night . alternately cover with tea towel and use a hair dryer and dont get too close as the heat will disstort the case .... hope this helps Regards vortash
Posted on May 14, 2009
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
This morning, all the buttons on the phone have stopped working except for 7, 8, 9. It was fine last night, and only this morning, I couldn't turn off the alarm on it and none of the other buttons are...
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 14, 2010 | Nokia 6234 Cellular Phone
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
"Not allowed to dial" new c5000 wi-fi phone
Guys I had the same problem with the k599 Sciphone and none of the solutions found on the internet helped me. New chinese models tend to restart after testing is over and this results in turning the wifi application on. So I spent many hours on thinking how to bypass this function and this morning I woke up with an idea that really worked!! The steps are quite similar with the ones followed to debug older models:
put 2 chips on cell
Disable WLAN.
1-enter in factory mode *#3646633#
2-go to RF Test Tool
3-choose GSM, confirm OK!
4-go to Power scan
5-Select Band DCS1800 click OK
6-the cell frozen
7-wait for 3 minutes testing
8-while testing connect to a pc using the USB cable (do NOT select ANY of the options appearing on the cell screen)
9-Click the CENTER button of the cell until you go back to principal menu
10-go to settings/network settings and choose GSM Preferred or any other option (except WLAN only!!)
In this way the cell does not reboot, and the wifi application stays off, so the option can now be changed...
Hope this helps!
Greetings from Greece!
e-mail me to akiss_bd@hotmail.com if any questions..
Sep 03, 2009 | Dual Electronics CECT P168 Cellular Phone
My phone had been dropped in the toilet....and everything works except for the top half of the qwerty keyboard and the menu buttons how do i fix it
take it to the company and they may trade it in for a new one and plus there is no possible way to fix water damage
Jun 05, 2009 | HTC G1 Smartphone
No buttons work except for end button, and was dropped in the water.
i have the same problem, only mine was spelt in beer. oppps :( but i know this also happens to my friends phone and she told me to take the battery out for about a night or so and see what happens!! who knows, we will find out together i guesssss!
Apr 26, 2009 | AT&T LG CU720 Cell Phone - Silver
I dropped my phone in water everything works except some of my keys on the phone such as the letters and number. Everything else works
You should take the phone to a mobile service center and have them fully service the phone for you.
Aug 13, 2008 | T-Mobile Cell Phones
Touch pad keys don't work, except the one to turn phone off
Oh my gosh!!!! It worked!!! It really worked! I had my phone in the back pocket of my jeans when I went outside in a heavy rainstorm to get to my car. When I got to school (I'm a teacher) I realized my phone wouldn't work...except for the power button. None of the other buttons worked at all...AND...GULP....the water indicator sticker inside was red. I got my second graders busy, then looked on here for some help on what to do. I read the comment about how the person laughed, but banged the phone on her knee after reading about banging the phone....not thinking it would work...and it DID! I'm SO happy!!!! Thank you
Mar 18, 2008 | Motorola Mobility RAZR V3
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
My buttons ain't working
Take the phone apart ,the battery and the casing . Dry using warm air,maybe a hair dryer. Put together,if still the problem then try to replace the batter this is a common.
Jun 27, 2007 | Motorola Mobility T722i
Nokia 6133 Cellular Phone Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
