Question about Ricoh Aficio SP C811DN-DL Printer
SC548-00 - Ricoh Aficio SP C811DN-DL Printer
You have to:
press the arrows "up" and "down" at the same time for five seconds
press the OK button
a new menu appears
select option 2: ENGINE
with the arrows navigate and select option number: 5 (MODE)
now press the right arrow until you see "810. SC RESET".
press ok
and later press "execute" (you will see it in the screen of the printer)
press "ESC" until you exit all menus
power off the printer for 30 seconds
and.... VOILá........
thats all
Posted on Jun 18, 2009
  • 1 more comment
  • typografos21 Oct 25, 2010
    thank u thank u THAAAAAAANK u and a big BIG hug :)
  • WannaBeTech Apr 25, 2013
    Awesome, it works like lucky charm!
  • Eric Adam
    Eric Adam Dec 13, 2014
    Thank you did exactly as you said, needed help on a Sunday and got it.
  • 95 Answers
548 is a fusing unit rotation error. I think this is a level A code, which means it needs to be reset by a service tech. Some of the causes are the fuser was not pushed in corectly. There are two sensors on the machine frame front side, the fuser could have knocked one of these out. Both of these problems are caused by pushing the fuser with one hand. It needs to be pushed in carefully with two hands. The other cause could be the fuser induction roller is coming apart, in that case the fuser needs to be replaced.
Posted on May 20, 2009
Service call SC548
SC 548 - Fusing unit set error or fusing unit installation error,differ to copier models.Try reset by open/close the front door or enter in SP mode and turn ON/OFF the copier.
Mar 25, 2013 | Ricoh Office Equipment & Supplies
SC548 AND SC990
Sc548 can generally only be reset by entering service mode, and generally is caused by a defective thermistor (thermostat) in the fuser, and/ or power fluctuations. Sc990 is a software issue. I'd consider a new HDD> You'll need a tech for these problems.
Aug 13, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Mar 11, 2011 | Office Equipment & Supplies
Gestetner dsm645 error code sc548 solutions of free
SC548 is fuser belt rotation error, check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion, I think they have been modified, but I don't have the part number, sorry. Allso check the firmware is up to date.
Feb 19, 2011 | Gestetner DSm645 Digital Imaging System
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
Aug 16, 2009 | Lanier UNKNOWN
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio SP C811DN-DL Printer Logo
1,138 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
