Question about Tappan TGF320 Gas Kitchen Range
I thank i need to replace thermostat in tappan oven the temp goes to about 550 degree no matter were the oven knob is set Icould use a parts break down on to replace the thermostat in the oven
    President:
  • 1,865 Answers
Go to this link and select your model number. It will take you to a set of drawings and parts list
http://www.apwagner.com/index.php?main_page=part_finder&searchType=model_number&keyword=tgf320
Posted on May 14, 2009
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Jan 01, 2009 | GE JGRS14 Gas Single Oven
Oven tempature is 35 degrees celcius less than set tempature even after adjusting oven tempature control
if you read your tappan instructions, it will tell you to turn your oven to 550 degrees, then press and hold the bake button for 15 seconds. it will blank out and go to 0. adjust temp up or down accordingly. peace out.
Sep 28, 2008 | Kitchen Ranges
Oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Uneven oven temp.
Check to make sure the bake element is coming on. If so try replacing the thermostat.
Oct 07, 2007 | Kitchen Ranges
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan double oven
I have the digital timer oven and also cannot find the manual. You have to set the bake time timer, I think for 3 hours. Then you set the oven knob on clean and turn on the temp knob, probably to full but I don't think it matters. When you engage the lock, the clean light should come on/ When the oven reaches high temp, the lock light will also be on.
Mar 29, 2007 | Tappan TEF242 Electric Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
497 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
