Question about EA - Electronic Arts NEED FOR SPEED MOST WANTED (Nintendo GameCube) Release Date: 11/16/2005 for GameCube
How to finish the second race against the blacklist 10 on the need for speed most wanted? everytime i started i says blown engine
    President:
  • 17 Answers
You must switch the car settings that says automatic or manual,you must chose automatic cause if you pick manual you must press shift again and again.
Posted on May 28, 2009
How correct toro l/mower engine racing
Check the idling setting screw is not holding open the throttle butterfly common fault to fix if the engine races esp when no load is applied the idle throttlexpostion is to high thus the engine runs faster at idle turn the screw located on either the butterflyistelf so less screw threes is against the carb body this should start lowering the idle speed of the engine it should be around the 900 RPM approx for idling and top rev of 3500 at full throttle a rev counter is displaying a extra high rev count the it's the oil governed at fault or malfunctioning or sticking this will cause and engine to race badly to the point of engine destruction eventually
You may need to adjust the movement of the governing leavers etcetera best done by qualified servicing personnel a lawnmower mechanic etc
Aug 03, 2014 | Toro Garden
Tip
Beginner tips for F1 2010
On September 24 the formula of the first game for<b> Xbox 360</b> and <b>PS3 </b>came out in 2006, created by Codemasters. Since I had the game who played the career mode and online, until now, I prefer to play against real opponents, such as line speed racing. The career mode, I started this treatment and had 10 points for my first season when my team had 0 points, but the team did not renew my contract so he moved to Virgin Racing. The career mode is very good, but I was disappointed by the media interviews that seem to ask the same questions after each race. But overall a very good game and by far the best formula for a game created. To this end im going to give advice on how to win (or finish in the top 3) racing online.<br />
on Jan 03, 2011 | Video Game Consoles & Games
In need for speed most wanted how do i play the second race against baron in blacklist 10 everytime i start racing it says blown engine... so i want to know how to play
The secod race is a DRAG in Harbour & Ocean.
1. Second event is a Drag race, which will require you to push additional button to shift gear up or down "check your controls for configuration" to avoid blown engine sticking on gear 1. as you can see while accelerating the speedometer rises before it reaches the red boundary shift gears up to avoid blown engine.
Another simple race. Be sure to avoid the truck that'll appear on your left (#1). You won't have much time to make a correct manoeuvre. Be sure to change lanes often. use Mitsubishi Lancer EVO VIII its handling is good on tight corners an also fast.
Hopefully this information helps.
Thank you for using FixYa.
Aug 12, 2011 | Computers & Internet
I have a 2008 f-250 and it throughs two codes p1000 and p0297 wat do these mean
Hello, The Code p0297 means that the truck was driven beyond 85MPH. There is a speed calibration built into the PCM and on the truck it trips at 85. The second Code 1000 means that a scan was started and the scan was not finished now the info still wants to be downloaded.
So you have one code to alert you that someone was running the Winston Cup race and that should clear in time or you can wipe it with a scanner. Then you have the other Code telling you that you started a test and did not finish it. It will probably clear when you let it download.
Aug 10, 2011 | 2008 Ford F 250 Super Duty 4WD
My races in map are finish
If your races in maps are finished and you don't know what to do or from where to earn money for customization then,follow these steps:
  1. Get over to The Garage.
  2. Then to World Map.
  3. You will see a map of that Stage like Stage 1 , Stage 2 and so on and also the events in that stage.
  4. Scroll down to the events and watch out for the Event Status.
  5. Select the event whose status is Not Completed.
  6. Start the race.
  7. And as the count down ends Restart the race.
  8. Win that event or race.
  9. You will get money for it and also the parts will be unlocked.
Have fun! =)
Aug 08, 2009 | EA - Electronic Arts Need for Speed:...
Nfs mw exits as soon as i start a race event
you have cracked it or nt ......want u cn do u know once you uninstall it it and then re install it then againthe same prblm arise then buy another disc of the same game dudue.....
Apr 17, 2009 | EA - Electronic Arts Need for Speed : Most...
Instructions
This si a mini guide I hope it helps...please rate me ...thanks ....The Fang
Career Guide
Settings
Use the 12 race schedule and turn Yellow Flags ON. You can advance quicker with the shorter length season and the Yellow Flags often give you a break by allowing you to catch up for the restart.
Startup
  • Sponsors: Don't take the hardest (best paying) sponsorships right away. You're only paid if you actually meet those expectations.
  • Team: For now, go with the cheapest talent available. If costs are equal, go with a pit crew guy with the better speed rating. You should also keep an eye out for a good potential rating
Sponsorship
The way to bigger and better sponsorship is to raise Sponsor Prestige. When it reaches 60, you will get tougher and more lucrative offers. Hopefully, you will also have a good enough car to achieve these new goals.
  • Expectations and Income: This tells you what the sponsor wants from you and how much they will pay you when you meet their standards.
  • Prestige: Prestige is a measure of how respected this sponsor is in the world of NASCAR. Typically, a sponsor with higher prestige will have more difficult expectations and better income. Prestige changes depending upon your race finish. The better you finish, the more likely that sponsor's prestige will go up. You will receive a bonus payout anytime a sponsor's prestige reaches a new all-time high. Also, when a sponsor's prestige reaches the next level (60, 70, 80, 90), new offers will become available from sponsors in that location. These new offers will have more difficult expectations, but significantly better income.
  • Happiness: Happiness is a measure of how your sponsor feels about your performance. This is based primarily on whether or not you meet their expectations. When a sponsor's happiness is above 70, you will receive bonus income.
Team
In the early going, especially when you don't really need to build new equipment, go with the cheapest Builders. This will help keep costs down and maximize your income.
Your Team is broken down into 2 types: Builders and Pit Crew. The average ratings of your Pit Crew determine the quality of your stops. Their average speed will determine overall how quick your stops will be. Their average skill will determine the likelihood of pit crew fumbles. Overall, speed is probably more valuable than skill.
Your Builder's ratings are used in the construction of new equipment.
A crew's Happiness is very important. A crew member will perform at his indicated rating when his Happiness is at 75. When it is less than that, their actual performance is up to 15% lower (Happiness of 50). The reverse is also true: Happiness of 100 will give 15% better performance than the indicated rating.
The Happiness is dependent upon your race finishes. Each crew member has an expected finish that is based upon his average rating. When you do better than expected, their happiness will increase.
R&D
This is perhaps the most important aspect of your operation. You need to invest in R&D early and often in order to improve your cars' performance. Each level of R&D equates to an increase of 10 in the base value of that rating. For example in the beginning, your R&D level of Engine Power is 0. Your base rating for Engine Power on new equipment is 50. When you finish R&D on Engine Power 1, the base rating will be 60.
This base rating is averaged with your Builder's rating (adjusted by Happiness) to determine how good that piece of equipment will be. In the above example with Eng. Power of 1 and an Engine Builder with a Power rating of 66 (and Happiness of 75), any new engine you build would have a Power rating of about 63.
So, after you finish your first piece of R&D, go to your Team Builders menu and fire the guy with the same rating as the R&D you just finished. So, if you've finished Eng. Power, fire your Engine Builder and get a new one who has ratings in the 60's. This new Builder will be able to take full advantage of the latest R&D.
Garage
This is the most complex area of your operation, although not at first. As your equipment improves, you'll want to visit this area often to make sure your equipment is in good Condition. For every 2 points of Condition loss, your car will lose 1 point off of its ratings down to a minimum value of 50. Condition loss depends on how much you abuse your car during a race.
But since the difference between a 53 and a 50 isn't that much, you shouldn't worry about repairing your equipment until you build your first new engine or chassis. This will save you some cash.
Once you do finally build something new, you'll need to start monitoring its Condition and repairing as necessary. Overhauling will increase an older piece of equipment's ratings utilizing your latest level of R&D. However, until you have several levels of R&D in each area, it's usually more cost effective to just Build new equipment.
General Racing
Practice each track before you qualify/race. Your car handles very differently than it does in Quick Race. You can also make some fairly easy tweaks to your Car Setup that will greatly increase your lap times in the early races of career. You'll probably want to increase the wedge setting a bit to tighten the car (so it isn't so skid happy). But the single biggest improvement you can make is to your Gear Ratio. Adjust 4th gear until you are maxing out at 9000 RPM at the end of the straightaways. Going any higher than 9000 could damage your engine.
ALWAYS qualify for the race. Not only are at least one of your Sponsor expectations based on qualifying, but starting as close to the front as you can will help your race finishes.
Be patient and take what the track and other racers will give you. Remember that at the beginning of a career, you're not competing for the win. Set your sights on finishing 40th and run a race that will get you there. Don't be overly aggressive; if you lose control and crash with yellow flags OFF, you won't be able to recover for a good finish.
In the early going, you're pit crew is not very good, and you will lose some time in the pits. You can overcome this with some pit strategy (2 tire stops on low tire wear tracks like Daytona) or by just trying to gain as many spots as you can before the mid-race pit stop.
Here's a guideline to how you should be qualifying and finishing depending upon the average rating of your car:
50: ~40th
60: ~30th
70: ~20th
80: ~10th
90: ~1st
These are for Veteran difficulty with a player who can usually finish in the Top 5 in Quick Race. Rookie mode is significantly easier.
Secrets
Unlock Tiburon Speedway
If you have a save from any 2003 EA Sports game on your hard drive or memory card, the Tiburon Speedway track will be automatically unlocked.
Unlock Fantasy Drivers
Enter Extra Drivers as the Create-a-Car neame to unlock all fantasy drivers.
Mar 25, 2009 | EA Sports Video Game Consoles & Games
Kitchenaid mixer races when turned on
Hi. Get in touch with Kitchenaid Parts and order a new Control Board. If your mixer is still covered by warranty it's free. ricardok45
Dec 23, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Cant get cheat codes for need for speed underground rivals
Boss Cars There are 4 boss cars to unlock in the game:
Tank: 1969 Dodge Charger
Triple Dub: Subaru Impreza WRX STi
DJ Wes: Chevrolet Corvette Z06
GT King: Nissan Skyline R34 GTR
These cars are unlocked by beating them in Boss Races and are placed in a special location in your Pocket Garage.
The boss car the game chooses to race against you depends on the level of the race and the car you are using. You need to defete the same boss car in multiple different Boss Races in order to unlock that car. You can choose from any of the Boss Races in Circuit Mode and Street Cross and Drag from Quick Play.
Unlockable How to Unlock DJ Wes: Chevrolet Corvette Z06 Race against this Boss Car in a TROPHY-Level Boss Race using a JAPANESE car. GT King: Nissan Skyline R34 GTR Race against this Boss Car in a TROPHY-Level Boss Race using an AMERICAN car. Tank: 1969 Dodge Charger Race against this Boss Car in a CUP-Level Boss Race using a JAPANESE car. Triple Dub: Subaru Impreza WRX STi Race against this Boss Car in a CUP-Level Boss Race using an AMERICAN car.
More parts for your vehicle On any race set, complete the last race in that event with a gold medal and you will unlock bonus parts for your vehicle.
Computers and Shortcuts In Lincoln Connector an easy way to win is to simply force the computer into the first shortcut of the race. Once the computer is in the shortcut the car will freeze for a period of time. This freezing can even last for up to a lap.
Nitrous Glitch In drag racing if you tap the nitrous button instead of holding the button down your car will accelerate at a faster speed
Dec 23, 2008 | Sony PlayStation Portable (PSP) Console
EA - Electronic Arts NEED FOR SPEED MOST WANTED (Nintendo GameCube) Release Date: 11/16/2005 for GameCube Logo
121 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
