I try to power on my samsung HLR617W, the lights on the front flash, Lamp flashes in green, Timer flashes in green and standby temp flashes in red. What problem does this indicate?
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
