Question about E-Machines eMachines Desktop PC
Start up When I turn my emachines pc on it just "idles" high. Nothing comes up on the monitor. It will just keep running like that until I manually shut it off. I've had my pc for at least 2 years and so far its been great.
  • Anonymous Apr 22, 2008
    hello i have a emachine w2646 my pc was working great and i turned it on one morning and nothing came up on the monitor but the green light on the power button started flashing and the keyboard lights started flashing too so i changed the monitor same thing nothing on the monitor i tried leaving the pc on awhile same thing power button flashing keyboard lights flashing ive never seen anything like this oh ya none of the cd rom drive trays will open either thank you Rick Hill
  • 47 Answers
Try to boot in safe mode, if you still get nothing try a dirrent monitor, just to rule out the monitor then we can work on the computer.
Posted on Oct 15, 2007
SOURCE:
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
Auto Processing
There is nothing just update your antivirus and check your system for virus
Feb 27, 2009 | E-Machines eMachines Desktop PC
I have a emachine T6420
ohk i also have an emachine make sure you have the moniter hooked up all the way i have had the same problem
Dec 31, 2008 | E-Machines T6420 PC Desktop
Hard starting after rebuild
My name is Dennis and I also have the model you are having difficulty with and I can only repeat the instructions from the owners manual (with personal comments) because they have always served me adequately I hope that will serve your needs.
IDLE ADJUSTMENTS:
There are three adjustment screws on the carburetor labeled
H (for High speed MIXTURE)
L (for low speed MIXTURE)
T (for idle SPEED SETTING)
They are located just above the primer bulb. If your saw floods so soon in the starting process the idle mixture setting can be set too rich and the speed may be set too slow. Remember the chain will not move when the idle speed is set correctly with a WARM ENGINE!
Adjust the idle speed to just below chain movement WITH A WARM ENGINE this is just below the activation RPM of the centrifugal clutch. Let the engine run at a higher speed than idle until it is warm -- 3 min -- you may have to keep goosing it until then.
Please don't exceed the limits of the plastic limiters when making adjustments.
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moving. Adjust clockwise to increase speed. C clockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the
LOW SPEED MIXTURE (in) clockwise in 1/16 a turn increments NO MORE at a time because a two cycle needs to run at a setting for a short time to really prove the setting. don’t run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct until the engine is warm.
Good Luck
Glad to be of assistance - please rate the solution because I will learn from your rating. Thank you
Nov 07, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
T5082 keeps abruptly shutting down
Sounds like it may be overheating. If you get warning beeps on startup that sounds high, low, high low, it is overheating. you should inspect and clean the fan on the processor with a vacuum or compressed air ans also clean the power supply area with a vacuum to clear all the dust out. Inspect and wipe any other dust away from the motherboard and card inside. After restarting, it still goes off, check that the fan is running during startup. If not, the fan needs to be replaced at a nominal cost. This is an easy fix. If this all fails, let me know so we can troubleshoot everything together.
Nov 19, 2007 | E-Machines eMachines Desktop PC
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
E-Machines eMachines Desktop PC Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
