Question about Dell Computers & Internet
Bumped front of my modem by accident and i lost connection....
Bumped front of my modem by accident and i lost power to my computer. When turning it back on i get a beeping noise repeatedly. This has happened before but it has been a long time. How do i fix this? The graphics card is good there was no problems with it until i bumped it. Please help
  • deedracrespo May 14, 2009
    this is not a laptop, this is a desktop, MDL # WD1600AAJS-75PSAO.. THIS HAPPENED ON MY PC A WHILE AGO AND IT JUST STARTED WORKING PROPERLY ONE DAY.. WHATEVER IT IS IT CAN'T BE A MAJOR PROBLEM BECAUSE IT WORKED FINE. I CHECKED AND THERE IS NOTHING LOOSE INSIDE.
  • 114 Answers
I think that when u bumped, something went loose. Open up your computer and just make sure everything is seated properly. You RAM and your graphics card being the main things to check. Re-seat them if possible. That should take care of the problem.
Posted on May 14, 2009
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I'm having trouble connecting my emachine to a cable modem.
Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    Jan 21, 2011 | E-Machines eMachines Desktop PC
    Cmment utuliser ce modem
    1. Save your work and shut down your PC.
    2. Connect the coaxial cable from the coaxial jack in your wall to the coaxial port on the rear of the modem. Turn the connector clockwise until the cable is firmly connected to the modem. Gently tug on it to make sure it is connected.
    3. Connect the appropriate cable, USB or Ethernet to the matching jack on the rear of the modem. Connect the other end of the cable to the appropriate port on your computer.
    4. Connect the modem's power adapter to a surge suppressor or a dependable wall socket.
    5. Press the power switch on the front of the modem to turn it on. Power up your PC. If you opted to use the USB connection method, you may have to install the appropriate drivers. Check your owner's manual for specifics.
    6. Launch your web browser http://192.xxx.xxx to verify Internet access.
    Dec 04, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
    Seagate HDD Harddrive 320 GB:How To Get Data Recovery?
    Connect HD in another computer as a slave drive.
    Nov 28, 2010 | Seagate Computers & Internet
    After losing power I lost network conaction
    Try to power cycle the whole network and make sure that everything connected properly. Turn of the pc then the router and lastly the modem. Wait for 5 minutes then turn on the modem then router and pc. Modem should be connected to the internet port on the router and pc to the ethernet ports.
    Jun 29, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
    Beeping noise and will not start back up
    Hi there.
    Open the side panel on the computer case (make sure its turned off and the power cord is removed from the back) take out the system memory (ram), get a clean dry paintbrush and clean the brass contacts on the memory and also clean any dust away from the slots it goes into, once you are happy that all the dust has gone reseat the memory making sure its well seated and clipped into place, close the side panel, return the power cord and turn on the PC, hopefully this will sort the problem out.
    Please post back with the results.
    Good luck and thanks for using FixYa!!
    May 14, 2009 | Dell Computers & Internet
    Cant get to internet thru linksys etherfast cable/dsl router
    Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
    Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
    Connect to internet
    Just turn your modem off for 30 seconds and also you router if you have also turn your computer off for 30 seconds also.
    Then after 30 second turn modem and router on then after that the computer, that should be ok now.
    IF still not working call your ISP.
    Hope that helps..........
    Aug 03, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
    4100 Light flash no connection
    *if the DSL light on your modem is blinking..
    TRY: using different filters// check physical connection
    IF: not resolved call ISP for a trouble ticket for their line department
    *if all the lights constantly blinks
    DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
    NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
    HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
    Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    Computers & Internet Logo
    44 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
