Question about Cobra 19 ULTRA II (40 Channels) 2-Way Radio
I have a cobra cb and just re-hooked it up, after it had been sitting in my shed. Everything seems to be working except I'm not getting any sound, not even any squelch noise.Whats my problem???
Make sure the mic is not broken and if it is stop useing it and get a diffrent mic
Posted on May 15, 2009
I have a Cobra 29ltd CB with no sound coming from the internal or external speakers. So I went out and bought another Cobra 29ltd thinking that the old one was shot. Hooked up the new one and the same...
are you using the antennas that are installed thru the mirrors or the ones on the side of the truck. If you are using them you should make sure that they are connected to the coax. some just get thrown together ,antenna to mount then one end of coax to ??? so take a multi meter and set it on x1.Touch bottom of the antenna and the connector that come out of the dash. If you are connected you should get a reading. If you are not ,then you will have a problem hearing anyone because you are not connected to the antenna but the coax. If the connection is good to go then I would try running a ground wire to the chassie and maybe even a ground strap.
Mar 09, 2013 | Radio Communications
I hooked silver streak 250 linear to my cobra 29 lx not working
how is the radio getting out without the 250 hooked up?
Feb 19, 2012 | Cobra Radio Communications
Hello i own a cobra 29 ltd classic from 1993 today i was talkin skip like crazy!! running about 100 watts out of a texas star modulator!! i left for a while came back talked for a while everything was good...
sounds like the amp got hot and shorted on the bias.. and is keyed up a few watts. to fix you will have to have the amp repaired. new power transistor. to fix. 3174269649 Texas.
Dec 12, 2010 | Cobra 29 LTD CB Radio
Alright i have a cobra 29 ltd classic from 1993 bought for 110 bucks.. everything was workin great!! i was talkin skip all day today and all of a sudden boom the meter just swung all the way backwards and...
Sounds like you blew the finals. When you "RUN POWER", you increase chances of something going wrong and it is mainly caused by a high SWR reading. You fried something for sure. Better get those SWR's checked while you are there.
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Cobra 75 wx st no sound/speaker does not work. Everything else seems OK according to display
Hi, my name is John. try putting a external speaker in back of radio and see what happens, might need to replace internal speaker, or something internal. Let me know, I will post the process here......Hope this was helpful..
Aug 01, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
No Transmitting, no RX sound, but can hear speaker click on...
Hi there!!
The symptom sounds like a bad Microphone connection or a bad microphone!! The Cobra has a built in circuit that wont allow you to hear anyone until the microphone is plugged in and the no transmit part will also do the same. Try another microphone that is wired right for that radio before you do anything else!! let me know!!
Dennis
Mar 18, 2009 | Cobra 29 NW CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Mar 23, 2008 | Cobra HH 38 WX 40-Channels Handheld CB...
NO sound
Make sure the switch is in the CB position. If this is so, then you may have a bad switching transistor or a bad diode in the board. Also on some of the weather band cobras I have worked on in the past, I have found bad pll chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 19 ULTRA II (40 Channels) 2-Way Radio Logo
88 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
