Question about D-Link DSL 200 (DSL-200) Modem
Installing when i first tried to install the modem it froze. so i had to restart and try again. upon running the setup i get this message "the dsl modem is already installed. to upgrade the software, you must remove the current software and then run setup again later.", so i try to uninstall, but the problem is that there is no uninstall file. in fact there is no file relating to the modem at all. i've searched in control panel, device manager and everything. but cant find anything. can anyone help me?
  • 131 Answers
Re: installing
Ques: What OS are u using.
then, are you having broadband connection.
which interface you are connecting (say Network or USB)
Posted on Jan 09, 2008
0 characters
3 Points
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
Oct 25, 2010 | AT&T High Speed DSL Modem
I need a dlink dsl 2520u driver
go to from there on the left hand side click on support. Then click D-Link products specs, downloads, setup guides, troubleshooting & how to's. Now on there are 2 boxes saying SELECT. On the left box select DSL and on the 2nd box select 2520u.Clcik download and from there you can select the driver depending on your OS.
Jan 09, 2010 | D-Link DSL 200 (DSL-200) Modem
Can't connect internet. message reads error 633,
Here is a tip to work normally your modem, transfer it to another PCI Slots in the Motherboard and install again with the driver freeware provided. See to it that no other programs run on the system that interrupt your modem installation and diagnose it.
Please rate me.
Thank you.
Sep 15, 2009 | HP BCM5705 Modem
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
Jun 20, 2009 | Modems
Current modem working fine with ATT DSL. I want to install a second modem (2wire) by direct connection to same DSL phone connection (in different room). I have hooked up other modem, filled in user ID and...
Is that second location also a DSL line? You may have to consult with AT&T to see if the DSL line runs to that second location.
What are you trying to accomplish? By adding a second modem, you essentially create two separate networks. Why not use a switch and connect it to the first modem, which would allow you to connect more PCs.
Apr 16, 2009 | 2wire (1000-000057-000) Modem
Installation problems
disable the firewall and try again.
sometime the firewall prevent the verification of yur computer mac address and signon.
Nov 23, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Jan 29, 2008 | Efficient Networks SpeedStream 5100 Modem
Blinking light on the DSL modem.
Unfortunately it sounds like the modem may need to be replaced. I had the same issue. Even after doing a complete shutdown, resetting all the cables, restarting the modem and then the computer, it still did not work. After you get the modem replaced, I would suggest you get a spare, possibably from e-bay, so if this happens again, you will not be without DSL Service.
Dec 17, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Acer 56 kbps v.92 modem...i cant install modem
Hello there, sounds to me like a softwere problem. Try downloading the drivers again from the website of the make of the modem. Install them again - if you're getting the same message after, Download anti-virus FREE AVG you can find this at this link for windows: Install this run it on a test see what it says and you may find your problem. if not then you could do a deep clean and fully re-install windows xp - REMEMBER TO BACK-UP ANY FILES YOU WANT TO KEEP BEFORE DOING SO. in the meantime good luck Raverbaby keepin it hardcore!!!!! = (htid) hardcore till i die !
Apr 08, 2007 | Acer FM56 ITU/2 (91.AC001.209) Modem
D-Link DSL 200 (DSL-200) Modem Logo
195 people viewed this question
Top D-Link Modems Experts
David Payne
David Payne
Are you a D-Link Modem Expert? Answer questions, earn points and help others
