Question about Samsung HT-DS610 System
F61 problem on technics sa-eh790
Disconnected everything from amp and powered up still getting f61 and goes to standby when all parts are connected there is a low sound output but still get f61 and shuts down to standby the fan does come on a minute then shuts off when the f61 appears any help would be greatfull thanks scott.
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: No picture or sound
take you tv to tech you have damaged your microchip and component in the power supply
Posted on Mar 19, 2007
ctf1800
  • 4402 Answers
SOURCE: overheating of 56 in projection screen, samsung
do you get any blinking lights? if so how many times and how many lights?
Posted on Dec 13, 2007
jdvillanueva
  • 2098 Answers
SOURCE: My TV keeps shutting itself
This kind of symptoms is an indication of faulty either the actuator board or the thermal fuse(sensor).
First check the resistance of the thermal fuse (it is mounted in small board at the top of the lamp housing), it should be shorted(0 ohms), if you dont have a multemeter, install jumper across the terminal of the thermal fuse and try to power on the unit. If the unit power up, replace the thermal fuse, if not replace the actuator board.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Aug 27, 2011
  • 40 Answers
SOURCE: why does a Samsung plasma ps51f4500ar shut down after 1 minute
check the voltages printed in the sticker in the back of the panel and adjust that values with a DM.
well this is Lg,but is the same procedure for almost all plasmas brands
Posted on Jan 28, 2015
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
Need a new amplifer for a sh-eh790 as my main audio output has gone
before throwing out your old amp open it up and check the processor inside the amp its a little black thing behind the fan. if that dont work then contact me again. and i will suggest more things. but if you really want to replace it would you give me your old amp please and here is a link to a amp for you. i know its correct as i have the same system. I LOVE TECHNICS PRODUCTS. http://cgi.ebay.co.uk/Technics-SA-EH790-AMPLIFIER-/130501062833?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item1e627830b1#ht_646wt_1141
Nov 14, 2009 | Technics SCEH790 CD Shelf System
Sound keeps going off on my technics sa-eh790 problem is the same whichever input is used the system goes off if the volume is turned up any ideas anyone?
yeah i get that alot, when playing from soundblaster cant go higher than 20, its probably just a safe, or overheat or something, there really is no solution)
Oct 29, 2009 | Technics SCEH790 CD Shelf System
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
Im having a erorr saying f61
F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.
Jan 24, 2009 | Audio Players & Recorders
Technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
Samsung HT-DS610 System Logo
433 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
